I think I'm in the right place to ask this question. I'm working on my second ever radio... I'm not sure what a specific part in my radio is, that needs to be replaced. But I'll try to describe it.. This might be a resistor, it's red cloth covered and the inside is like a spring with silver tip ends it goes to a pin on the 42 tube and the otherside goes to a ground point. This part is split, mostly broken almost in half...... Anybody have any idea what this part is? Sorry for my lack of knowledge, I wish I could explain it better.
Craig
The Crosley 157 has a 220 ohm resistor, #26 in schematic, from pin #5 of 42's to chassis. Even though the covering is burnt off, as long as the coil spring isn't broken, it may be working. If you replace this resistor use one rated 2 watts or more.
Check the address below for schematic.
http://ww3.nostalgiaair.org/schematics/CRO/CRO_3-30.gif
: Hello:
: I think I'm in the right place to ask this question. I'm working on my second ever radio... I'm not sure what a specific part in my radio is, that needs to be replaced. But I'll try to describe it.. This might be a resistor, it's red cloth covered and the inside is like a spring with silver tip ends it goes to a pin on the 42 tube and the otherside goes to a ground point. This part is split, mostly broken almost in half...... Anybody have any idea what this part is? Sorry for my lack of knowledge, I wish I could explain it better.
: Craig
Thank you very much for the help with the resistor.
Could you tell me how you came up with 2 watts? Is it because of the tubes or location?
Thanks again
Craig
: Hi Craig
: The Crosley 157 has a 220 ohm resistor, #26 in schematic, from pin #5 of 42's to chassis. Even though the covering is burnt off, as long as the coil spring isn't broken, it may be working. If you replace this resistor use one rated 2 watts or more.
: Check the address below for schematic.
: http://ww3.nostalgiaair.org/schematics/CRO/CRO_3-30.gif
: Norm
: : Hello:
: : I think I'm in the right place to ask this question. I'm working on my second ever radio... I'm not sure what a specific part in my radio is, that needs to be replaced. But I'll try to describe it.. This might be a resistor, it's red cloth covered and the inside is like a spring with silver tip ends it goes to a pin on the 42 tube and the otherside goes to a ground point. This part is split, mostly broken almost in half...... Anybody have any idea what this part is? Sorry for my lack of knowledge, I wish I could explain it better.
: : Craig
