Philco 41-280
4/5/2002 10:04:21 AMDale R Johnston
Help! local oscillator will not operate in push button position, radio works fine otherwise on all bands, have replaced caps, cleaned switches, etc. Resistors and wiring check OK. Riders 12-63
4/5/2002 10:22:31 AMNorm Leal
Hi Dale
Check if your oscillator tube, XXL, is operating. You should have a negative grid voltage when it operates. Swap tubes if it doesn't operate. These tubes can be on the verge of oscillation. Coil location can make a difference.
Other than that there are only switch contacts. Since you already cleaned them make sure no contacts are broken.
: Help! local oscillator will not operate in push button position, radio works fine otherwise on all bands, have replaced caps, cleaned switches, etc. Resistors and wiring check OK. Riders 12-63
