AMI jukebox CC amp schematic, or a link to a page online.
3/31/2002 11:15:44 AMJohn McPherson
There was a link about 2 years ago to an online schematic for this amp, but I cannot find it in any of my bookmarks anymore.
Failing that, might anyone happen to have a scan? I already know where I can purchase the manual for the Juke (actually several), but I really only need a schematic for the amp/turntable control chassis.
If you try the email address, it should generate automatically, but you will need to change the "AT" to @ and "DOT" to a ., this has effectively eliminated exposure to the web spiders that collect email addresses off of discussion lists as this one.
Otherwise:
neutrodyneATvisiDOTcom
3/31/2002 9:56:34 PMEdd Whatley
: There was a link about 2 years ago to an online schematic for this amp, but I cannot find it in any of my bookmarks anymore.
: Failing that, might anyone happen to have a scan? I already know where I can purchase the manual for the Juke (actually several), but I really only need a schematic for the amp/turntable control chassis.
: If you try the email address, it should generate automatically, but you will need to change the "AT" to @ and "DOT" to a ., this has effectively eliminated exposure to the web spiders that collect email addresses off of discussion lists as this one.
: Otherwise:
: neutrodyneATvisiDOTcom
John:
Seems like 40 yrs ago since my servicing them; but often I'm called on to fix friends of friends units
in homes.Mostly SeeBurgers...found this site some time back . If the ckt config on a CC is P/P 6L6
outs and 6SN7 in front end tone ckt maybe this will work.WWW.verntisdale.com/schem.htm
Tnx & 73's de Edd
3/31/2002 11:58:32 PMJohn McPherson
I knew I had found it a long time ago, and I do back up the bookmark file, but I have no idea why that one got away.
Thanks Again.
: : There was a link about 2 years ago to an online schematic for this amp, but I cannot find it in any of my bookmarks anymore.
: : Failing that, might anyone happen to have a scan? I already know where I can purchase the manual for the Juke (actually several), but I really only need a schematic for the amp/turntable control chassis.
: : If you try the email address, it should generate automatically, but you will need to change the "AT" to @ and "DOT" to a ., this has effectively eliminated exposure to the web spiders that collect email addresses off of discussion lists as this one.
: : Otherwise:
: : neutrodyneATvisiDOTcom
: John:
: Seems like 40 yrs ago since my servicing them; but often I'm called on to fix friends of friends units
: in homes.Mostly SeeBurgers...found this site some time back . If the ckt config on a CC is P/P 6L6
: outs and 6SN7 in front end tone ckt maybe this will work.WWW.verntisdale.com/schem.htm
: Tnx & 73's de Edd
