3/22/2002 9:21:55 AMCraig Funni(11398:0)
I am restoring a 20's vintage TRF reciever. The brand is Neodyne by Steinway Radio Co. of Chicago. It has a component that looks like a glass fuse and it is labeled as follows "POLYGRID POLYMER MFG. CORP NY M9"
Any idea what this might be? Also any info on this radio would be nice. Thanks,
Craig
3/22/2002 1:40:51 PMCRAIG(11400:11398)
I FOUND OUT WAHT IT IS. IT IS A 8 MEG OHM RES. COULD NOT MEASURE IT ON MY VOM
THANKS,
CRAIG
3/22/2002 2:15:51 PMNorm Leal(11401:11400)
Hi Craig
They are called "grid leak resistors". Used at the detector grid. Most range from 1 meg to around 5 but even 8 should be work.
: I FOUND OUT WAHT IT IS. IT IS A 8 MEG OHM RES. COULD NOT MEASURE IT ON MY VOM
: THANKS,
: CRAIG
3/23/2002 4:44:12 PMAlan Douglas(11424:11401)
Polymet made lots of mica and paper condensers. 8 megs is high for a grid leak, but if it works, you can use it. Probably 2 to start with.
