crosley playtime
9/3/2014 11:03:24 AMdoug
have replaced the 4 .1 caps under the green box,big mess lots of tar,now the smaller silver box under chassis,can only see writing on top of box saying 4 is this an electro or cap and is there anything else in this small can.it has 4 leads coming out of it.
9/3/2014 2:56:31 PMdoug
:have replaced the 4 .1 caps under the green box,big mess lots of tar,now the smaller silver box under chassis,can only see writing on top of box saying 4 is this an electro or cap and is there anything else in this small can.it has 4 leads coming out of it.http://mcclellans.com/images/Crosley%20124-M/ChassisBottomAfter.jpg
9/3/2014 11:19:34 PMCarl T
::have replaced the 4 .1 caps under the green box,big mess lots of tar,now the smaller silver box under chassis,can only see writing on top of box saying 4 is this an electro or cap and is there anything else in this small can.it has 4 leads coming out of it.
Doug,
What's the model number?
Carl T
9/4/2014 7:31:09 AMdoug
:::have replaced the 4 .1 caps under the green box,big mess lots of tar,now the smaller silver box under chassis,can only see writing on top of box saying 4 is this an electro or cap and is there anything else in this small can.it has 4 leads coming out of it.
:http://mcclellans.com/images/Crosley%20124-M/ChassisBottomAfter.jpg
:model 124,sorry about that,senior moment
:Doug,
:What's the model number?
:Carl T
9/4/2014 5:38:16 PMdoug
::::have replaced the 4 .1 caps under the green box,big mess lots of tar,now the smaller silver box under chassis,can only see writing on top of box saying 4 is this an electro or cap and is there anything else in this small can.it has 4 leads coming out of it.
::http://mcclellans.com/images/Crosley%20124-M/ChassisBottomAfter.jpg
::model 124,sorry about that,senior moment
::i am having a hard time with the sch,on crosley 124.i dont know if mine is a 124-1 or 124.it is in the playtime grandfather clock.next part is when checking volts after installing new caps,i have no grid or plate volts on the 2 tubes #27.i have 0 volts.on pin #2 and pin #3.124-1 sch.shows neg.volts on grid and 124 shows pos.volts.where does the voltage come from on these 2 tubes.the other tubes in chassis are with in specs.
::What's the model number?
::Carl T
