This is a regenerative set and will have poor selectivity unless the regeneration control is correctly set, which is just on the hairy edge of oscillation. If you can't adjust the set to break into oscillation, you probably have an open coil connection
or oxidized tap selector contact.
CV,
thanks
can get the radio to do the typical regen sounds, the squeals and such. Just that on some taps especially. You can turn the dial from total left to total right and hear 1520 , which is 50,000 watt on the whole dial. It acts like my home made crystal radio.
My Miraco and Standardyne, you can see by turning the rheostats, the filament "GLOW"change. This one, it's like full blast all the time.
One thing I have noticed is that on the book capacitor. There is a small film or sheet that came lose from the plate that is closest to the side of the radio.
If, that needs to be fastened. I wouldn't know how to do it.
The person where I bought the radio from. Had a complete with tubes Radiola RCDA. But, he said the transformers were more likely bad. feel the 52 is a better choice.
Shouldn't the + and - at the tubes have a for the plus side, a -5 volts and the minus side have no volts? On mine, the plus as zero volts and the minus has a -5 volts.
Here is the set's schematic:
http://www.angelfire.com/retro2/jimm/page16.html
