8/1/2014 1:04:03 PMmike(112735:0)
Hey hi all...in my restoration of my zenith 8s463 should i replace all the littel brown "mica-mold" caps?? They have the three and 6 dot color scheme.. ...
8/1/2014 2:01:23 PMNorm Leal(112736:112735)
Hi Mike
If you are sure they are mica no need to replace these caps. Mica caps are usually 10 to 500 pf (mmf). Mica-Mold did make paper caps in these packages. Most of them will be .001 mf or higher values. These will be leaky and require replacing.
:Hey hi all...in my restoration of my zenith 8s463 should i replace all the littel brown "mica-mold" caps?? They have the three and 6 dot color scheme.. ...
8/1/2014 4:22:41 PMDoug Criner(112737:112736)
Mike: whenever I replace a suspicious cap, after removing it I check for leakage - just as a matter of curiosity. On small value caps, I just use a multimeter on the ohms scale.
8/1/2014 4:27:32 PMDoug Criner(112738:112737)
Or, I test it with my Fluke meter on the capacitance scale. If the capacitance shows up as lower than what it is supposed to be, that indicates leakage.
I also have an Eico tester that checks the cap at rated voltage.
