7/25/2014 7:06:31 PMdoug(112639:0)
i am in need of a meter for this tester.anyone have a meter that will work?tried other forums,no answer.
7/26/2014 1:29:35 PMJohn(112651:112639)
:i am in need of a meter for this tester.anyone have a meter that will work?tried other forums,no answer.
If your meter is truly bad you can get one from this guy, but they are not cheap: http://www.alltubetesters.com/parts.htm
Be sure to verify that C3, 50MFD @ 6V electrolytic in parallel to the meter is O.K. John
7/26/2014 3:51:53 PMSMITH(112653:112651)
::i am in need of a meter for this tester.anyone have a meter that will work?tried other forums,no answer.
:If your meter is truly bad you can get one from this guy, but they are not cheap: http://www.alltubetesters.com/parts.htm
:Be sure to verify that C3, 50MFD @ 6V electrolytic in parallel to the meter is O.K. John
:JOHN THE METER SPRING IS BROKEN.
