FM Converter?/Philco 42-1015
7/24/2014 7:15:58 AMDaveF
On the 42-1015, which has the old FM bank on it, the previous owner has a small metal box that is attached to the antenna leads on the chassis. At first I thought it was one of those antenna boosters, but it has a decal on it (partial), and states "FM convertor, 88.5- then it is missing". Is it possible there was a convertor from the old to new FM out there in the early 50's? I have not restored the chassis yet, so I cannot test the band to see whats up with it.
7/24/2014 7:22:49 AMRichard
:On the 42-1015, which has the old FM bank on it, the previous owner has a small metal box that is attached to the antenna leads on the chassis. At first I thought it was one of those antenna boosters, but it has a decal on it (partial), and states "FM convertor, 88.5- then it is missing". Is it possible there was a convertor from the old to new FM out there in the early 50's? I have not restored the chassis yet, so I cannot test the band to see whats up with it.
Here is a little information...
http://userpages.bright.net/~geary/fm/fmconverter.html
Richard
7/24/2014 8:03:29 AMDaveF
::On the 42-1015, which has the old FM bank on it, the previous owner has a small metal box that is attached to the antenna leads on the chassis. At first I thought it was one of those antenna boosters, but it has a decal on it (partial), and states "FM convertor, 88.5- then it is missing". Is it possible there was a convertor from the old to new FM out there in the early 50's? I have not restored the chassis yet, so I cannot test the band to see whats up with it.
:Here is a little information...
:http://userpages.bright.net/~geary/fm/fmconverter.html
:Richard
Thank you. It is a 5 inch small box, maybe 1.5 inches high that dangles from the two pronged aux. antenna input. I will open it up and have a look inside. I think it must be some aftermarket converter to receive at least a few stations on the high or low end of the old FM band.
