Philco switch
7/23/2014 7:59:11 PMjim l
I have 2 Philco radio, a 41-245 and a 41-285 that have bad push button on/off switches. Can these be found new or used?
7/23/2014 8:17:05 PMSteve Davis
:I have 2 Philco radio, a 41-245 and a 41-285 that have bad push button on/off switches. Can these be found new or used?
Look here http://www.philcoradio.com/notebook/41226.htm
Steve
7/24/2014 7:02:42 PMjim l
Could someone give me other sites. no luck on this one
7/25/2014 5:55:08 PMGeorge T
::I have 2 Philco radio, a 41-245 and a 41-285 that have bad push button on/off switches. Can these be found new or used?
:Could someone give me other sites. no luck on this one
Hi jim I, try email (parts2many@aol.com) David might be able to help you out. Did you try contact cleaner on the buttons? You can kinda get to them and check the contacts for corrosion. Good Luck, George T
7/26/2014 8:32:06 PMEddie
:::I have 2 Philco radio, a 41-245 and a 41-285 that have bad push button on/off switches. Can these be found new or used?
::Could someone give me other sites. no luck on this one
:Hi jim I, try email (parts2many@aol.com) David might be able to help you out. Did you try contact cleaner on the buttons? You can kinda get to them and check the contacts for corrosion. Good Luck, George T
I repaired the power switch on my Philco 41-300 console by drilling out the 2 copper rivets and finding a bad solder connection to one of the switch contacts. I had already used Caig on it, but it was still intermittent. It was really tedious to reassemble it properly, and I spent a lot of time figuring out how to fasten it back together - I think I might have ended up using a short 2-56 or 3-48 screw on one side, and steel wire on the other. It was tedious, but I saw some intriguing switch innards, and respect for that robust but simple Philco switch.
Eddie
