RCA Model T6-1 Rider 6-83
7/23/2014 7:10:25 PMBob
6a8 tube no signal touch top of tube with screwdriver signal that can be tuned appears, pin voltage #3 105 volts (low s/b 263) pin #6 zero. C16 Elect cap when I test voltage I get a signal. Caps & resistors tested ok.Any ideas??
7/23/2014 9:33:17 PMNorm Leal
Hi Bob
Open coil L7 or L11. Look for broken connection or a green spot of corrosion.
http://www.nostalgiaair.org/Resources/823/M0015823.htm
:6a8 tube no signal touch top of tube with screwdriver signal that can be tuned appears, pin voltage #3 105 volts (low s/b 263) pin #6 zero. C16 Elect cap when I test voltage I get a signal. Caps & resistors tested ok.Any ideas??
7/23/2014 9:57:12 PMBob
:Hi Bob
: Open coil L7 or L11. Look for broken connection or a green spot of corrosion.
Looked at both 7&11 maybe corrosion, thats the area I've looking at,
