Lafayette Model B-21
7/21/2014 6:26:06 PMDave Froehlich
Hello All,
Is it true that this model is exactly the same as a Montgomery Ward Airline model 62-185, but actually made by Wells Gardner? I read this online but I'm double checking. The radio I'm working on says "Lafayette" on it. But there's no model number anywhere on it. But it does match a picture of the one online, that is identified as a Model B-21.
7/22/2014 6:45:47 AMDave Froehlich
Hello Again,
Yes, it's exactly the same. I just replaced all the paper and electrolytic capacitors. It has a problem that seems to be in the RF stage. If I connect the antenna to the antenna lead, the signal is weak. But if I connect the antenna to the next stage, the signal is quite strong. I'll find the problem.
:Hello All,
: Is it true that this model is exactly the same as a Montgomery Ward Airline model 62-185, but actually made by Wells Gardner? I read this online but I'm double checking. The radio I'm working on says "Lafayette" on it. But there's no model number anywhere on it. But it does match a picture of the one online, that is identified as a Model B-21.
:Thanks,
:Dave
7/22/2014 10:00:17 AMDave Froehlich
Hello All,
R6 was the problem. I noticed it was wrong while replacing the capacitors. So I took it out. It's supposed to be 16K ohms 2 watts. Some previous "servicer" put a 140 ohm 20 watt resistor in it's place. I replaced it with an 18K ohm NOS resistor that had drifted to 17K ohms and screen voltages returned. The radio is fully operational. All I have left to do is replace the dial belt and I'm done.
It's a very nice looking radio. The chassis and dial look almost brand new. It looks much newer than 1936 inside.
:Hello Again,
: Yes, it's exactly the same. I just replaced all the paper and electrolytic capacitors. It has a problem that seems to be in the RF stage. If I connect the antenna to the antenna lead, the signal is weak. But if I connect the antenna to the next stage, the signal is quite strong. I'll find the problem.
:Dave
::Hello All,
:: Is it true that this model is exactly the same as a Montgomery Ward Airline model 62-185, but actually made by Wells Gardner? I read this online but I'm double checking. The radio I'm working on says "Lafayette" on it. But there's no model number anywhere on it. But it does match a picture of the one online, that is identified as a Model B-21.
::Thanks,
::Dave
7/22/2014 12:32:04 PMBrianC
Let us know if you need anymore help....(insert smiley face)
7/22/2014 12:41:10 PMDave Froehlich
Is this an unusual radio to find? I'm going to move on to the next radio, since the Lafayette is all restored.
:Let us know if you need anymore help....(insert smiley face)
