Emerson 126
7/8/2014 6:18:57 AMfrank goddard
The 126 Emerson I am working on is really very poor in the volume and sensitivity deparment. Good tube tests and no cap.resistor problems. Antenna is 50 feet so fair input there. Loudspeaker and volume control are my next suspects but before I pull them to bits would appreciate any other input. Many thanks.
Frank. Doncaster England.
7/8/2014 7:42:59 AMJohnnysan
:The 126 Emerson I am working on is really very poor in the volume and sensitivity deparment. Good tube tests and no cap.resistor problems. Antenna is 50 feet so fair input there. Loudspeaker and volume control are my next suspects but before I pull them to bits would appreciate any other input. Many thanks.
:Frank. Doncaster England.
Sounds like an alignment issue to me.
7/8/2014 9:24:02 AMCV
This is a four-tube set (one of which is a rectifier) so when new it was never a stellar performer in either the volume or sensitivity categories. However, if you have a strong local station it should be able to play it at adequate volume. Did you check the B+ voltage level? If low it will impair both set sensitivity and volume (as well as tone quality).
7/8/2014 2:28:44 PMfrank
:This is a four-tube set (one of which is a rectifier) so when new it was never a stellar performer in either the volume or sensitivity categories. However, if you have a strong local station it should be able to play it at adequate volume. Did you check the B+ voltage level? If low it will impair both set sensitivity and volume (as well as tone quality).
7/8/2014 2:30:33 PMfrank
Many thanks for the info.Will check voltages and see what we have.
Frank
