7/5/2014 2:46:15 PMBob Van Enkenvoort(112335:0)
I have a Grundig 3010 that worked when I got it, but that was 10 years ago. However, when it came from Poland the tuning glass was in pieces. I brought the pieces into work to see if they could be scanned, and printed out on a decal. (Not sure if it would have even worked.) The janitor tossed the box that said: SAVE in big letters on it. So I am looking for a replacement or replica so I can get it working, if possible. Was the tuning glass on the 3010 used in other models? Any suggestions?
7/5/2014 6:55:44 PMCV(112336:112335)
You might poke around here to see if anything will work for you. Appears to have a 3012 dial glass image, which is possibly similar to your 3012. The link below is one of two lists; you may want to Google "radiomuseum grundig dial glass" to access the other one.
http://www.radiomuseum.org/r/allefirmen_skala_skalenglas_dial_all.html
7/6/2014 3:40:37 AMCV(112339:112336)
Mske that: "Appears to have a 3012 dial glass image, which is possibly similar to your 3010."
