magnavox
7/3/2014 1:34:43 PMpaul
hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
7/3/2014 1:47:36 PMjohnnysan
:hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
Johnnysan--
7/3/2014 3:09:28 PMpaul
::hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
:It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
:Johnnysan--
thank you for the reply. have a sams photofact coming soon.
7/3/2014 8:17:40 PMCH
:::hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
::It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
::Johnnysan--
:thank you for the reply. have a sams photofact coming soon.
Gary at www.oldradioparts.com has everything. I noticed he has a power xfmr 275V at 200ma 5v at 3A 6.3V at 4A costing $23.00 His website is called "Playthings of Past" He is
Gary is good to work with. I have purchased many parts from him. I forgot to get the part# will follow up
CH
7/3/2014 8:23:08 PMCH
::::hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
:::It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
:::Johnnysan--
::thank you for the reply. have a sams photofact coming soon.
:Gary at www.oldradioparts.com has everything. I noticed he has a power xfmr 275V at 200ma 5v at 3A 6.3V at 4A costing $23.00 His website is called "Playthings of Past" He is
:Gary is good to work with. I have purchased many parts from him. I forgot to get the part# will follow up
:CH
The part # is 1328-305 RCA 906128-5011. If you go to his website go to "Radio Parts" then "Transformers" then "Power" Gary always wants you to e-mail him first to make sure it is in stock
CH
7/4/2014 10:18:25 AMpaul
:::::hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
::::It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
::::Johnnysan--
:::thank you for the reply. have a sams photofact coming soon.
::Gary at www.oldradioparts.com has everything. I noticed he has a power xfmr 275V at 200ma 5v at 3A 6.3V at 4A costing $23.00 His website is called "Playthings of Past" He is
::Gary is good to work with. I have purchased many parts from him. I forgot to get the part# will follow up
::CH
:The part # is 1328-305 RCA 906128-5011. If you go to his website go to "Radio Parts" then "Transformers" then "Power" Gary always wants you to e-mail him first to make sure it is in stock
:CH
:hi. maybe this will help. the Westinghouse amp is H-480c12 sams 271 folder 17. appears that it does have 6.3v filaments. am I correct? thank you paul w
7/20/2014 3:57:51 PMpaul
::::::hi. need to build a power supply for a magnavox tube tuner. model CR330AA. like to use it on a Westinghouse tube amp. tube amp has been recapped and new 4.1k power resistor. old resistor was dead shorted. any ideas will be helpful. thank you paul w
:::::It looks like the power supply is about 275 volts DC. The filter cap inside is rated at 475. You will need 6.3 volts AC at 3 amps for the filaments. The Sams is 268-8; I have it if you need it.
:::::Johnnysan--
::::thank you for the reply. have a sams photofact coming soon.
:::Gary at www.oldradioparts.com has everything. I noticed he has a power xfmr 275V at 200ma 5v at 3A 6.3V at 4A costing $23.00 His website is called "Playthings of Past" He is
:::Gary is good to work with. I have purchased many parts from him. I forgot to get the part# will follow up
:::CH
::The part # is 1328-305 RCA 906128-5011. If you go to his website go to "Radio Parts" then "Transformers" then "Power" Gary always wants you to e-mail him first to make sure it is in stock
::CH
::hi. maybe this will help. the Westinghouse amp is H-480c12 sams 271 folder 17. appears that it does have 6.3v filaments. am I correct? thank you paul w
:hello again. had this tuner working for several hours. tried it the next day and resistor r19 1000 ohm resistor cooked. found arcing in L11 AM output transformer. um!! where do I find one of these. yes arcing is from mica type thing to ground. thank you
