Alternatively, you could use a polyurethane wiping varnish after you cleaned the panel. This would be a lot faster and wouldn't demand total panel disassembly, but the results probably wouldn't be as mirror-like as would be possible with a buffing wheel.
Thanks, It's an old Standardyne trf
:Alternatively, you could use a polyurethane wiping varnish after you cleaned the panel. This would be a lot faster and wouldn't demand total panel disassembly, but the results probably wouldn't be as mirror-like as would be possible with a buffing wheel.
Might also try 'Flitz.'
