6/3/2014 7:05:49 PMJoe(112012:0)
Hello,
When making an antenna is it best to use insulated or uninsulated wire.
Thanking you in anticipation.
Joe
6/3/2014 7:35:36 PMEddie(112013:112012)
:Hello,
:When making an antenna is it best to use insulated or uninsulated wire.
:Thanking you in anticipation.
:Joe
Insulation makes virtually no difference in signal strength, so the decision depends on your needs. Insulation could protect it from contact with voltage, or improve appearance, or reduce corrosion.
Eddie
6/4/2014 2:02:37 AMJoe(112014:112013)
Thank you for your advice Eddie.
Kind regards,
Joe
