Superior Insturment TD-55 tube tester
3/7/2002 7:52:18 PMMatt Mincer
ok, I know it's a long shot but here goes. I have a Superior Instruments
Co. tube tester model TD-55 made in 1956. I an trying to test tubes in
an old amp, but some of the tubes are not listed in the tube chart. The
amp is newer than the tester so my guess is that the tubes were not
available at the time the tester was made. So, does anyone have any idea
where I could get a newer tube chart for this? I ran a search for
Superior Instruments Co. but every company in the world comes up. They
all think they are superior I guess.
Matt
3/7/2002 8:27:42 PMAlan Douglas
Superior stopped advertising around 1958, and I suspect went belly-up. Unless Coletronics offered updated charts, as they did for some other New-York-area brands of tube testers, you're probably out of luck.
The TC-55, advertised in 1956, cost only $26.95 and couldn't have done much more than check emission. You might find similar tubes in your chart, that would give the basic setup data, so you could at least get comparative results. Typically these emission testers connected all elements in parallel, except the cathode, then applied a low AC voltage to the tube, in series with a load resistor, and metered the current flow.
6/2/2002 6:39:17 PMRobert Steele
:ok, I know it's a long shot but here goes. I have a Superior Instruments
:Co. tube tester model TD-55 made in 1956. I an trying to test tubes in
:an old amp, but some of the tubes are not listed in the tube chart. The
:amp is newer than the tester so my guess is that the tubes were not
:available at the time the tester was made. So, does anyone have any idea
:where I could get a newer tube chart for this? I ran a search for
:Superior Instruments Co. but every company in the world comes up. They
:all think they are superior I guess.
:Thanks
:Matt
I too, have a model TD-55 tester but I don't have any manuals/charts.Would anyone care to send me a copy of these or tell me where I canobtain documentation?
6/3/2002 8:11:19 AMDon Black
Hi Matt, Can you please list the tubes you are trying to test. Perhaps we can suggest some similar, older tubes for the settings.
Don Black.
::ok, I know it's a long shot but here goes. I have a Superior Instruments
::Co. tube tester model TD-55 made in 1956. I an trying to test tubes in
::an old amp, but some of the tubes are not listed in the tube chart. The
::amp is newer than the tester so my guess is that the tubes were not
::available at the time the tester was made. So, does anyone have any idea
::where I could get a newer tube chart for this? I ran a search for
::Superior Instruments Co. but every company in the world comes up. They
::all think they are superior I guess.
::Thanks
::Matt
:I too, have a model TD-55 tester but I don't have any manuals/charts.Would anyone care to send me a copy of these or tell me where I canobtain documentation?
