~ Clip the end of the wire from it's attaching point -- leaving a little tail of wire for attaching the new wire to.
~ Cut a piece of new wire to approx. proper length and tack-solder one end of it to the loose end of the old wire.
~ Clip the other still attached end of the old wire... again, leave a little tail at the connection point.
~ Now, use the old wire to pull the new wire through the chassis... Doing so will retain the proper routing for the new wire... In some cases this is important.
~ Clip the new wire free from the old one and solder it in place, using the little wire tails to attach to.
~ This procedure will enable you to match the original wiring perfectly.
Dennis
The note about retaining the original wire routing is very important for some sets, particularly in the high-gain audio amp stages- and deviating from the factory wire routing often results in sets having an aggravating hum.
Besides a small sidecutter, I find that it is helpful to use a surgical needleholder to tease out and hold wires. These are available at vet supply stores (or well-stocked farm stores) and are rather inexpensive.
I have had success in using a tube of clear silicon sealant, squirting it in and around all the wiring using a small screw driver to lift and move the wire slightly to make sure of no shorts and getting the sealant in between the wires. Give 24 hour cure time. This has worked well when everything was too tight to try to change the wiring.
C Harris
