Replacement for 35Z5 tube
5/18/2014 4:55:15 PMMike
I am all out of 35Z5 tubes and can not find in my books a replacement for it... I would prefer not to do any rewireing....Was wondering if there is a replacement?? Thanks
5/28/2014 12:45:28 PMcodefox
:I am all out of 35Z5 tubes and can not find in my books a replacement for it... I would prefer not to do any rewireing....Was wondering if there is a replacement?? Thanks
Chreasp and easy to find. If I had a spare one I would donate. Maybe somene else has.
5/28/2014 1:55:22 PMNorm Leal
Mike
Do you have a 45Z5GT if so use that. Do you have a bad 35Z5 with filament between pin #2 and #3 open? If so jump pin #2 and #3 for testing a radio.
Could use a silicon diode between pin #5 and #8, cathode to pin #8. Should add series resistance to make up for lower voltage drop. If doing it this way also meed to add a resistor to take place of 35Z5 filament. A resistor around 250 ohms @ 10 watts will work.
::I am all out of 35Z5 tubes and can not find in my books a replacement for it... I would prefer not to do any rewireing....Was wondering if there is a replacement?? Thanks
:Chreasp and easy to find. If I had a spare one I would donate. Maybe somene else has.
