Important to have a well filtered filament (A) supply. If not filtered well turning up volume will increase hum.
Also be sure the grid side of an audio interstage transformer isn't open.
:What could cause a hum on the radio? Where would be the first place to look? The hum gets louder as I turn the detector knob up. Haven't picked up any staions yet. But that could be either I haven't tuned 1 in yet. Or, something needs to be done. thanks
Thanks.
Using a battery eliminator that works well. I took out a tube, put it back in and now. tubes don't light up and no voltage on the plate contact of tube base 1. The others do have voltage.
:::Jack
::: Important to have a well filtered filament (A) supply. If not filtered well turning up volume will increase hum.
::: Also be sure the grid side of an audio interstage transformer isn't open.
::::What could cause a hum on the radio? Where would be the first place to look? The hum gets louder as I turn the detector knob up. Haven't picked up any staions yet. But that could be either I haven't tuned 1 in yet. Or, something needs to be done. thanks
::You also need a well filtered B supply as well. Check your filter caps, clip in substitute caps for each filter. You need a good power supply before you can really do any meaningful troubleshooting.
::Lewis
:Thanks.
:Using a battery eliminator that works well. I took out a tube, put it back in and now. tubes don't light up and no voltage on the plate contact of tube base 1. The others do have voltage.
