My question is: I have many that are used...
Nearly every one of them show the shorts light on the
pilot heater,shorts tests switch 1-5 on a TV-7 DU..
except for sw point #2..
the filaments do light on these tubes.
What gives here?
Many Thanks for any discussion of this tube..
: My question is: I have many that are used...
: Nearly every one of them show the shorts light on the
: pilot heater,shorts tests switch 1-5 on a TV-7 DU..
: except for sw point #2..
: the filaments do light on these tubes.
: What gives here?
: Many Thanks for any discussion of this tube..
I suppose i could check this with one known to be working, but the handfull i checked yesterday had the same results...The manual states for BALST,,shorts 1-5
they failed all except for sw#2.
I'm afraid to try these in a circuit..
: What gives here?
Hi Dave
The 35Z5 does have a heater tap, pin #3. The pilot light is connected between pin #2 and #3. If on turn on the light flashes and burns out the section of the filiment between 2 and 3 is already open or the pilot light socket may be shorted to chassis. This will blow both the tube and light in a radio with chassis ground.
Some tube testers do not check 35Z5's properly, only using the tap to one side of the filament. I have no idea why your tester shows a short from pin #1 to pin #5. Pin #1 isn't used on a 35Z5. Use an ohm meter to verify continuity between pins #2 and #7 on the 35Z5's.
If the light & tube burn out after the 35Z5 is heated it's caused by a short on the B+ line or filter caps. However if your socket has a bad connection on pin #8, cathode, or pin #5, plate, you could get surges that can blow both tube and light. Try tightening these connections with a pliers.
: : My question is: I have many that are used...
: : Nearly every one of them show the shorts light on the
: : pilot heater,shorts tests switch 1-5 on a TV-7 DU..
: : except for sw point #2..
: : the filaments do light on these tubes.
: : What gives here?
: : Many Thanks for any discussion of this tube..
: Hi Dave
: The 35Z5 does have a heater tap, pin #3. The pilot light is connected between pin #2 and #3. If on turn on the light flashes and burns out the section of the filiment between 2 and 3 is already open or the pilot light socket may be shorted to chassis. This will blow both the tube and light in a radio with chassis ground.
: Some tube testers do not check 35Z5's properly, only using the tap to one side of the filament. I have no idea why your tester shows a short from pin #1 to pin #5. Pin #1 isn't used on a 35Z5. Use an ohm meter to verify continuity between pins #2 and #7 on the 35Z5's.
: If the light & tube burn out after the 35Z5 is heated it's caused by a short on the B+ line or filter caps. However if your socket has a bad connection on pin #8, cathode, or pin #5, plate, you could get surges that can blow both tube and light. Try tightening these connections with a pliers.
: Norm
Thanks Norm..yes, i didnt think to check it with an ohm-meter..i guess if pins #2 and #3 show a connection it's ok then!...
The TV 7 does both checks...it just said in the manual to perform shorts tests settings 1-5..? :D
They show good other wise and still have plenty of life.
thanks again.
: : : My question is: I have many that are used...
: : : Nearly every one of them show the shorts light on the
: : : pilot heater,shorts tests switch 1-5 on a TV-7 DU..
: : : except for sw point #2..
: : : the filaments do light on these tubes.
: : : What gives here?
: : : Many Thanks for any discussion of this tube..
: : Hi Dave
: : The 35Z5 does have a heater tap, pin #3. The pilot light is connected between pin #2 and #3. If on turn on the light flashes and burns out the section of the filiment between 2 and 3 is already open or the pilot light socket may be shorted to chassis. This will blow both the tube and light in a radio with chassis ground.
: : Some tube testers do not check 35Z5's properly, only using the tap to one side of the filament. I have no idea why your tester shows a short from pin #1 to pin #5. Pin #1 isn't used on a 35Z5. Use an ohm meter to verify continuity between pins #2 and #7 on the 35Z5's.
: : If the light & tube burn out after the 35Z5 is heated it's caused by a short on the B+ line or filter caps. However if your socket has a bad connection on pin #8, cathode, or pin #5, plate, you could get surges that can blow both tube and light. Try tightening these connections with a pliers.
: : Norm
: Thanks Norm..yes, i didnt think to check it with an ohm-meter..i guess if pins #2 and #3 show a connection it's ok then!...
: The TV 7 does both checks...it just said in the manual to perform shorts tests settings 1-5..? :D
: They show good other wise and still have plenty of life.
: thanks again.
The continuity test is ok for checking the filament. Actually checking pins #2 to #7 will test to pin #3 also. Pin #3 is a tap between the others. You are right the section between 2 and 3 will usually go open. You could make a plug in solid state replacement for testing if you are working on a lot of radios with 35Z5's. Use a 200 ohm 5 watt or greater resistor from pins 3 to 7 and a 50 ohm resistor 2 watt resistor between pins 2 and 3. Use a 1N4004 or similar diode from the plate, pin 5, to cathode, pin 8, with a 100 ohm resistor in series. You can always add a small fuse. This would make a nice test unit and you will not burn up 35Z5's.
: : : : My question is: I have many that are used...
: : : : Nearly every one of them show the shorts light on the
: : : : pilot heater,shorts tests switch 1-5 on a TV-7 DU..
: : : : except for sw point #2..
: : : : the filaments do light on these tubes.
: : : : What gives here?
: : : : Many Thanks for any discussion of this tube..
: : : Hi Dave
: : : The 35Z5 does have a heater tap, pin #3. The pilot light is connected between pin #2 and #3. If on turn on the light flashes and burns out the section of the filiment between 2 and 3 is already open or the pilot light socket may be shorted to chassis. This will blow both the tube and light in a radio with chassis ground.
: : : Some tube testers do not check 35Z5's properly, only using the tap to one side of the filament. I have no idea why your tester shows a short from pin #1 to pin #5. Pin #1 isn't used on a 35Z5. Use an ohm meter to verify continuity between pins #2 and #7 on the 35Z5's.
: : : If the light & tube burn out after the 35Z5 is heated it's caused by a short on the B+ line or filter caps. However if your socket has a bad connection on pin #8, cathode, or pin #5, plate, you could get surges that can blow both tube and light. Try tightening these connections with a pliers.
: : : Norm
: : Thanks Norm..yes, i didnt think to check it with an ohm-meter..i guess if pins #2 and #3 show a connection it's ok then!...
: : The TV 7 does both checks...it just said in the manual to perform shorts tests settings 1-5..? :D
: : They show good other wise and still have plenty of life.
: : thanks again.
: Dave
: The continuity test is ok for checking the filament. Actually checking pins #2 to #7 will test to pin #3 also. Pin #3 is a tap between the others. You are right the section between 2 and 3 will usually go open. You could make a plug in solid state replacement for testing if you are working on a lot of radios with 35Z5's. Use a 200 ohm 5 watt or greater resistor from pins 3 to 7 and a 50 ohm resistor 2 watt resistor between pins 2 and 3. Use a 1N4004 or similar diode from the plate, pin 5, to cathode, pin 8, with a 100 ohm resistor in series. You can always add a small fuse. This would make a nice test unit and you will not burn up 35Z5's.
: Norm
Thanks for the values, that's a great tip.!
will do..I found an Rca with the Thin base. You can get a clear view with a magnifer of the 2 tiny wires connected to a post at pin 3 and the single wires to 2 and 7..They appear to have a coating that stops just at connection..the actual wires are really very thin..
what a tricky old tube...
just did a hallicrafters S-38 that also has one.. i love my new s-38!
: Hi Dave
: Norm
I have a Heathkit tester that tests 35Z5s as good after the heater is blown. I remember several years ago I worked on a Firestone Fire Chief that had a jumper from pin 2 to pin 3. I was pretty green at the time and let a working jumper stay in place, but now that I have 2 radios on the bench with the same problem described in your messages, I wonder if my tube tester is testing from pin 3 to pin 7. Any advice before I create a fire hazard and try jumping pin 2 to pin 3?
-db
