Noise limiter: after market
5/13/2014 4:18:21 PMAUSTIN
In looking at a schematic for a short-wave set, there is a noise limiter installed on a factory set. The (output?) from the second group of coils (cans) after the 12BA6 goes to only one diode of a 12AV6. The other diode goes to the grid of the 12A6,through a resistor & then to ground. How does a noise limiter work & would it work on all sets? I'm thinking about static when there are sky (atmospheric) disturbances. Would a home "brew" work as well as a factory installed "brew"? Even so, how effective is a factory installed set-up (how much static can a noise limiter remove, & how does it work?
5/13/2014 8:10:59 PMCV
How radio noise limiters work:
http://books.google.com/books?id=5wkXHE2NZO8C&pg=PA191&lpg=PA191&dq=radio+noise+limiter&source=bl&ots=BYkJV1MFT_&sig=1JExP1F2jtJfLkS1Y3dS8U6aLgk&hl=en&sa=X&ei=VcByU4GeD8WHyASSloLIAw&ved=0CEEQ6AEwCA#v=onepage&q=radio%20noise%20limiter&f=false
