50B5 vs.50C5 ?
5/4/2014 1:49:29 PMAUSTIN
In reading bunker of doom on the 50B5 & the 50C5 they are the same. What is the difference between the two & why were they done that way? Was working on an old set with no tube markings on the chassis (or case) & didn't know which tube to put in the set. I have both & they have 7 pins each. Was a 50B5 used in one type of set (such as AC) & a 50C5 used in another type of set (such as AC-DC)? Is one type of tube newer style & one type older style as far as year is concerned? (i.e. 1940's & 1950's or 1950's & 1960's? Since they have the same power output-- & 7 pins I guess I'm lost!
5/4/2014 3:43:28 PMWarren
Same tube but not the same pin out.
5/4/2014 4:17:46 PMNorm Leal
The reason given for changing from 50B5 to 50C5 was UL requirement. A wrong tube in a socket was a shock hazard. What no one figured, now we have two tubes, 50B5 and 50C5. Get these wrong and you will have smoke.
:Same tube but not the same pin out.
