To correct this issue I read about a procedure that would insure a cold chassis by removing the AC power to the chassis and placing it on the switch. The neutral wire would ground to the chassis. This would require a polarized plug. I have the steps available but Id like some input before I do this.
http://www.the-s38-guy.com/Page_2.html
Some other AC/DC radios did use the metal chassis as a tie point for one of the AC line sides. These would be true "hot chassis" sets. In this case, it would be advisable to retrofit the set with a polarized-plug cordset and connect the wider blade plug wire (neutral) to the chassis. This of course assumes that your house was wired according to code so that "neutral" really is "neutral" (instead of "hot").
To Warren and CV: The Hallicrafters 5R10 I just finished with is the other issue. I'm told its a predecessor to the Hallicrafters S-38 model and runs the same risk if the chassis grommets fail. Metal case and all. Not to mention that chrome plate I have to touch just to change the settings. I would personally feel better with warrens suggestion regarding the S-38.
The 5R10 was a contemporary model to the S-38C. They have similar chasses but the 5R10 was a "stripped down" model lacking some of the S-38C's features such as BFO and T/R mode switch. The 5R10, like the S-38, had a "hot chassis" which would be a candidate for upgrading with a polarized cordset that connects the metal chassis (not the case) to the house neutral line. An external isolation transformer would be another approach. Either approach is probably overkill unless the set is to be operated in a damp environment(!) but I suppose that there is something to be said for "peace of mind".
Note: if you want additional protection, you can run the radio using an isolation transformer. Using a GFCI outlet or plug (similar to what hair dryers have) would also provide additional protection against shock.
:I understand that AC/DC radios inherently have a risk of being "hot" when their plugged in whether the switch is on or off. The blades on the plugs that came with these radios are the same dimension since polarization was not an issue at the time so the chances of power going through the chasis is 50/50 with an "authentic" replacement cord. Even if I know which side was "hot" Id like to rewire the radio to lessen those odds.
:To correct this issue I read about a procedure that would insure a cold chassis by removing the AC power to the chassis and placing it on the switch. The neutral wire would ground to the chassis. This would require a polarized plug. I have the steps available but Id like some input before I do this.
http://www.antiqueradios.com/forums/viewtopic.php?f=6&t=37924&sid=c95baf0bccba72a79bc277a033ef497c&start=20
I've suggested this different times but it leads to another problem. Low level audio signals are on the volume control. If the hot side is switched this leaves 120 volts 60 cycle on the switch. Being close to audio this can give some 60 cycle hum.
::Usually this would require re-wiring the power switch so it switches the Hot side of the line, not the chassis side and then reconnect it to the narrow side of the plug.
::Note: if you want additional protection, you can run the radio using an isolation transformer. Using a GFCI outlet or plug (similar to what hair dryers have) would also provide additional protection against shock.
:::I understand that AC/DC radios inherently have a risk of being "hot" when their plugged in whether the switch is on or off. The blades on the plugs that came with these radios are the same dimension since polarization was not an issue at the time so the chances of power going through the chasis is 50/50 with an "authentic" replacement cord. Even if I know which side was "hot" Id like to rewire the radio to lessen those odds.
:::To correct this issue I read about a procedure that would insure a cold chassis by removing the AC power to the chassis and placing it on the switch. The neutral wire would ground to the chassis. This would require a polarized plug. I have the steps available but Id like some input before I do this.
:::Problem solved. I used the procedure outlined by Chris 108 in "the antique radio forums". Its similar to at least three others Ive studied. Since the outlet the radio plugs into is correctly oriented I felt safe using it. The chassis is now cold. Here is the forum web page if anyone is interested. If in doubt, let someone else do it. Spend a few bucks and save a lot of grief.
:http://www.antiqueradios.com/forums/viewtopic.php?f=6&t=37924&sid=c95baf0bccba72a79bc277a033ef497c&start=20
:Hi
: I've suggested this different times but it leads to another problem. Low level audio signals are on the volume control. If the hot side is switched this leaves 120 volts 60 cycle on the switch. Being close to audio this can give some 60 cycle hum.
: Norm
That's probably RF-borne hum coming in the set via the antenna. When you tune in a station, AVC reduces sensitivity of the front end and suppresses the low-level hum.
