Original ballast drops 55 volts @ 300 ma. Resistance element is between pin #3 and #7 with a lamp tap on pin #8.
Although the part number was only used by Fada ballast configuration is fairly common. Might find a sub here:
http://www.oldradioparts.com/2a2fl.txt
:The lamp shunt resistor needs to be 42 ohms (6.3 V @ 150 mA) When paralleled with the #47 bulb, this will give 300 mA through the two. When you calculate the value of the main series voltage dropping resistor, just add 6.3 V to the sum of the individual tube voltages and subtract the total from 120 V to determine the voltage drop that the main resistor needs to provide at a 300 mA string current. Remember to derate the power resistor by 70% to ensure longevity.
:Dave
: Original ballast drops 55 volts @ 300 ma. Resistance element is between pin #3 and #7 with a lamp tap on pin #8.
: Although the part number was only used by Fada ballast configuration is fairly common. Might find a sub here:
:http://www.oldradioparts.com/2a2fl.txt
::The lamp shunt resistor needs to be 42 ohms (6.3 V @ 150 mA) When paralleled with the #47 bulb, this will give 300 mA through the two. When you calculate the value of the main series voltage dropping resistor, just add 6.3 V to the sum of the individual tube voltages and subtract the total from 120 V to determine the voltage drop that the main resistor needs to provide at a 300 mA string current. Remember to derate the power resistor by 70% to ensure longevity.
