REPLACING SPEAKER IN A PHILCO MODEL 40
4/27/2014 3:25:45 PMWalt
I HAVE A PHILCO MODEL 40-195 I WANT TO GIVE TO MY SON, BUT THE SPEAKER IS DESTROYED. I CAN'T READ THE OHM VALUE ON THE FIELD COIL IN MY SCHEMATIC, TO REPLCAE IT WITH A RESISTOR.
I AM TRYING TO REPLACE IT WITH A 15 OHM 12" JENSEN. I HAD IT WORKING AT LOW VOLUME AT ONE TIME, BUT I MESSED WITH IT AND BLEW THE AUDIO XFORMER. I HAVE A HAMMOND 125B MA XFORMER AND A HAMMOND 125E ma XFORMER. BOTH ARE PUSH/PULL AND THE CONNECTIOS APPEAR TO BE THE SAME FOR BOTH, BUT WILL THE 125B HANDLE THE CURRENT.
ONCE I KNOW WHICH IS THE BEST TRANSFORMER, I HAVE TO FIGURE OUT HOW TO CONNECT THE OUTPUT SIDE AND IT APPEARS THAT THE VOLUME IS CONTROLLED VIA A XFORMER TAP OFF THE OUTPUT SIDE. I HAVE REPLACED A FEW SPEAKERS, BUT NOT WITH THIS CONFIGURATION AND THE VOLUME CONTROL CONFIGURATION IS NEW TO ME.
4/27/2014 3:44:24 PMCV
Field coil resistance is 860 ohms. Many Philco consoles of this vintage used this value. The exact value is not critical if you are replacing with a resistor. A 1K ohm power resistor should be OK. It would be better (but more expensive) to replace the field coil with a filter choke, but the resistor alternative shouldn't be too bad, hum-wise. If it is, you can bump up the capacity value of the filter electrolytics by 50%.
FWIW, the 42 output tubes that your set uses are electrically the same as the 6F6, which may be easier to match, transformer-wise.
