Why most of the old radio sets are built with oversized resistors at every places where power resistors is not really required ?
Like 5 or 10 watts.
Even in AGC line which doesn't not carry much current, i sometime see a 2Megs/5 watts !!
1/4 watt would be enough.
Grid bias resistors are also way oversized.
Is it because small resistors were difficult to produce in the 30's ?
Modern resistors are much smaller for the same wattage. Here is a comparison:
http://www.philcorepairbench.com/resistcompare.htm
:Hi to all,
:Why most of the old radio sets are built with oversized resistors at every places where power resistors is not really required ?
:Like 5 or 10 watts.
:Even in AGC line which doesn't not carry much current, i sometime see a 2Megs/5 watts !!
:1/4 watt would be enough.
:Grid bias resistors are also way oversized.
:Is it because small resistors were difficult to produce in the 30's ?
It's possible that what you are seeing is the result of repairs done over the past several decades since the sets were made, where the repair techs might not have had the original power-rated resistors so they subbed higher-power ones. This is generally OK to do and the small additional cost could be passed along to the customer.
