If the hum is present when the volume control is set at minimum, check the installation of the two electrolytic caps in the set. Polarity must be correct (- goes to each side of the speaker field coil, + on both tie together and go to the rectifier cathode pin). If you find that one or both cap has been polarity-reversed, it will need to be replaced.
To clarify, don't just remove, reverse, and reinstall the same cap. Chuck it and install a fresh one. The old one is toast if it was reverse-biased.
CV:
He pointed out that the readings were taken with the 6X5 pulled. It sure sounds like shorted windings in the secondary of the power transformer.
Looks like a bad transformer. Fortunately, this is a fairly simple one- relatively low-power, and only two secondaries.
:Yup, that is what I was thinking. Thanks for the confirmation.
