phonaagraph
3/18/2014 6:34:36 PMbobby
i have a zenith record player i would like some help
in getting it to .play. it played about 15 years ago
it is a console type and has a nice cabinet the problem is when i turn it on a fuse blows would you give me help where to start no model number. has a 5y3 2 6bq5 i12au7 1 12ax7 tube got 2 12 inch speakers
thanks very much bobby
3/18/2014 7:39:42 PMLewis
:i have a zenith record player i would like some help
:in getting it to .play. it played about 15 years ago
:it is a console type and has a nice cabinet the problem is when i turn it on a fuse blows would you give me help where to start no model number. has a 5y3 2 6bq5 i12au7 1 12ax7 tube got 2 12 inch speakers
:thanks very much bobby
Bobby:
Whoa....not enough information...You need to use an Ohmmeter and find where a short is...we don't know the model, we can't look at a schematic and give you a clue. How many Ohms across the line cord? Where is the fuse? What does it protect? What is the model?
3/19/2014 1:13:53 AMGeorge T
::i have a zenith record player i would like some help
::in getting it to .play. it played about 15 years ago
::it is a console type and has a nice cabinet the problem is when i turn it on a fuse blows would you give me help where to start no model number. has a 5y3 2 6bq5 i12au7 1 12ax7 tube got 2 12 inch speakers
::thanks very much bobby
:Bobby:
:Whoa....not enough information...You need to use an Ohmmeter and find where a short is...we don't know the model, we can't look at a schematic and give you a clue. How many Ohms across the line cord? Where is the fuse? What does it protect? What is the model?
:Lewis
:Lewis
Hi Bobby, if it is when you turn on the phonograph the fuse blows check the black and white power wires going to the phono from the chassis. Have found several shorted out at the slides and hinges. Should be easy to spot. Best 2 U, George T
3/20/2014 3:05:18 AMStephen
First you need to determine if the short is in the phono motor or the amp circuit. I would try disconnecting inside the amp circuit and see if the phono motor runs. If it does, then you know the problem is in the amp. If not, you have a bad motor or a bad winding coil on the motor.
If the problem is in the amp circuit, I would connect a 60 watt light in series with the amp. This way you can tell if you have a short (Bulb goes bright). If you do, check for a shorted transformer winding, bad caps, and test the tubes. It is usually a good idea to replace all the electrolytic caps and filter caps before powering up an unknown device.
Note: Tube amps use HIGH VOLTAGE so be careful.
