RCA 7BX10 Stratoworld without 1L6 tube
3/11/2014 9:37:22 AMRICHARD MCKINNEY
Picked up one for $10 with bad 1L6. Too cheap to pay big price for tube I used a 1LA6 and mounted the socket for it just above the rectifier. Wired in new socket to the old 1L6 socket and after a recap the radio is playing fine.
3/13/2014 5:51:34 PMC Harris
:Picked up one for $10 with bad 1L6. Too cheap to pay big price for tube I used a 1LA6 and mounted the socket for it just above the rectifier. Wired in new socket to the old 1L6 socket and after a recap the radio is playing fine.
In my Zenith Trans-Oceanic Model H500 I do have a good 1L6 in it. If I want to run it on the broadcast band I exchange the 1L6 with a 1R5, no circuit changes, and it works fine. This helps save the 1L6.
C Harris
3/13/2014 9:39:54 PMNorm Leal
Hi
Using a 1R5 in place of 1L6 in a Zenith T/O works well on the broadcast band. Pin #5 is supplied to B+ through a resistor in these Zeniths. Pin #5 of a 1R5 is internally connected to pin #1, B-.
Not the same in all portable radios. Some supply B+ directly to pin #5 of the 1L6. If a 1R5 is inserted into these radio B+ will be Shorted to B-. In these radios pin #5 needs to be removed on the 1R5.
::Picked up one for $10 with bad 1L6. Too cheap to pay big price for tube I used a 1LA6 and mounted the socket for it just above the rectifier. Wired in new socket to the old 1L6 socket and after a recap the radio is playing fine.
:In my Zenith Trans-Oceanic Model H500 I do have a good 1L6 in it. If I want to run it on the broadcast band I exchange the 1L6 with a 1R5, no circuit changes, and it works fine. This helps save the 1L6.
:C Harris
3/13/2014 10:49:57 PMCHarris
:Hi
: Using a 1R5 in place of 1L6 in a Zenith T/O works well on the broadcast band. Pin #5 is supplied to B+ through a resistor in these Zeniths. Pin #5 of a 1R5 is internally connected to pin #1, B-.
Thanks for the update Norm. I did know about the pin connection of the 1R5 and the 68K res to pin 5 in my Zenith. I did not realize that other radios did a direct connect B+ to pin 5.
C Harris
: Not the same in all portable radios. Some supply B+ directly to pin #5 of the 1L6. If a 1R5 is inserted into these radio B+ will be Shorted to B-. In these radios pin #5 needs to be removed on the 1R5.
:::Picked up one for $10 with bad 1L6. Too cheap to pay big price for tube I used a 1LA6 and mounted the socket for it just above the rectifier. Wired in new socket to the old 1L6 socket and after a recap the radio is playing fine.
::In my Zenith Trans-Oceanic Model H500 I do have a good 1L6 in it. If I want to run it on the broadcast band I exchange the 1L6 with a 1R5, no circuit changes, and it works fine. This helps save the 1L6.
::C Harris
3/14/2014 1:01:18 PMAUSTIN
::Hi
:: Using a 1R5 in place of 1L6 in a Zenith T/O works well on the broadcast band. Pin #5 is supplied to B+ through a resistor in these Zeniths. Pin #5 of a 1R5 is internally connected to pin #1, B-.
:Thanks for the update Norm. I did know about the pin connection of the 1R5 and the 68K res to pin 5 in my Zenith. I did not realize that other radios did a direct connect B+ to pin 5.
:C Harris
:: Not the same in all portable radios. Some supply B+ directly to pin #5 of the 1L6. If a 1R5 is inserted into these radio B+ will be Shorted to B-. In these radios pin #5 needs to be removed on the 1R5.
::::Picked up one for $10 with bad 1L6. Too cheap to pay big price for tube I used a 1LA6 and mounted the socket for it just above the rectifier. Wired in new socket to the old 1L6 socket and after a recap the radio is playing fine.
:::In my Zenith Trans-Oceanic Model H500 I do have a good 1L6 in it. If I want to run it on the broadcast band I exchange the 1L6 with a 1R5, no circuit changes, and it works fine. This helps save the 1L6.
:::C Harris
::: When looking at PADGETTS transoceanic page,he doesn't describe the 1L6 to well. Your posting does a lot more in detail. The reason I watch this site is because I have a ZENITH G503 (something on that order, the one where the dial front cover) flips up & displays a nice dial scale, & turns the the set turns off & on so the battery is not left on accidently. WONDERFUL idea. Too bad ZENITH couldn't come up with this idea long time ago! I REALLY like your description of that circuit. The G503 is just an AM set. Will take your notes seriously & to heart when I work on that set later on.The set worked VERY WELL in the super fringe areas. Then I made a mistake (hopefully not) by making a substitute battery. What I did was to take a HUGE pile of good 9v. batteries & wire them in series to get 90v.,then wire all the positives in parallel & then all the negatives in parallel so I had a seperate 90v.+ & a seperate 90-. for the high voltage. The set worked for a while then the sound started to get weak. Then I put it aside. This was in the mid 70's., haven't tried it since. I had a total of 100 9v.(10 in series & then 10 across in parallel. Then I used 10 9v. in parallel for the filaments. At that time I got the 9v. for free, so no loss there. In the ZENITH book on transoceanic that set was described as LITTERLY reaching out for the WEAKEST stations & it DID EXACTLY THAT! I was impressed because other fringe area sets didn't play very well, even though they were described as being able to do that.
