The dropping resistor is a good idea. It may not be needed, but it's good to check for overvoltage.
Connecting the diodes to replace the 80 tube is a snap. Take two 600V PIV 1 amp silicon diodes, solder the cathodes together, then solder this joined lead to either of the two heater pins of the 80 tube socket (your choice, doesn't matter). Then solder the anodes of the diodes to the plate terminals of the 80 tube socket (one to each). You can solder these parts under the chassis and put a cover over the empty socket, or you can find a defunct 4-pin tube, remove the bottle, and install the two diodes in the empty base.
80 tubes aren't very scarce, yet. Nearly every set that was made in the USA from 1929-1935 used them; some set makers used them for much longer.
I have heard a story that the type 80 had the record for the longest lived active electronic part, that it was in production from 1927 to 1975. I think some transistor or diode may pass it up soon.
Best regards,
Bill Girmm
As I recall, 6V6GT went out of production in the 1960's. When did it come back?
Best regards,
Bill
Not sure that it ever really "went away", if you consider worldwide manufacturing. The communist bloc was around 15 years behind the west in abandoning tube technology in favor of solid-state devices. I can recall a Soviet pilot who defected in around 1974 along with the highest-tech jet fighter then in use in the USSR; the engineering team that analyzed it was astounded that its complex avionics suite was implemented entirely with vacuum tubes. No doubt their consumer electronics industry (such as it was) clung to vacuum tubes as well.
Presently 6V6 clones are being manufactured in Slovakia, Russia, and China. I bought some new Electro-Harmonix 6V6 tubes a few years ago, but I don't recall where they were made. They have a somewhat differently-shaped glass envelope than "classic" USA-made tubes, but they seem to work the same, at least in my Midwest KC-16.
The 6V6 was created to power car radios, and spread from there to home radios and amplifiers, including the Fender Champ. Yes they are still being produced as is the 12AX7, another tube that has had a long run.
I'm trying to imagine breaking the sound barrier in a tube-powered Russian jet. Nope, I can't imagine doing that. :>)
Actually, it's only been in the last twenty years or so that the good old CRT has been replaced by LCD displays in USA aircraft cockpits, both military and civilian, rotary- and fixed-wing.
Vacuum tubes can be made exceedingly durable. The USA artillery shell proximity fuze of WW2 made use of tiny ruggedized vacuum tubes which were fitted into the end of the explosive projectile. These had to withstand hundreds of Gs during firing and remain undamaged. This tube-based fuze technology was classified for quite a few years after WW2 was ended, which is possibly why it is today a little-known piece of mil technology history.
CV:
In the old days, the only CRT we had in the cockpit was the weather radar display.
As it turned out, the reliability of the color/BW CRTs was about an order of magnitude better than that of the complex electromechanical indicators that they replaced (although "backup" mechanical indicators were retained for many years alongside the bottle displays until Boeing finally dispensed with them altogether.)
After a very long run, these CRTs were displaced by LCD screen displays with fluorescent backlights, then by LCD screens with LED backlights. Eventually organic LED direct display will in turn displace these technologies in aircraft, just as they are starting to do in the commercial television market.
CV:
About the time that the 75/76 entered our fleet, I was transferred to a shop job (days only, weekends off, YAY!) so I didn't get to learn about the glass cockpits (we used Collins). I went from aircraft radio to electrical generation, worked on everything from the generators to the distribution busses. The 75/76 was the first digital generator control unit we ever saw, and we installed automated test equipment to test all of the seven or eight different airplanes we were flying at the time. (per-lenty of overtime in those days, working with three different companies on a new project, one that was new to everybody). Boeing uses a Sunstrand electrical system, different from anything we had ever seen before with a 8085 chip running the show for each generator. May I ask which avionics company you worked for? I have probably fixed some of your products.
CV:
Delta just LOVED Collins black boxes. I did too, compared to soome of the others we got with the L-1011.
