pilot light
2/13/2014 2:11:14 PMNick
Working on Montgomery ward AC. DC. tube radio late 40's
calls for a #47 pilot light, all I have on hand is a
#44. Will that work?
Thanks, nICK
2/13/2014 2:57:06 PMGeorge T
:Working on Montgomery ward AC. DC. tube radio late 40's
:calls for a #47 pilot light, all I have on hand is a
:#44. Will that work?
: Thanks, nICK
Hi Nick, it will work but it won't be as bright as the #47. It will however throw the voltages out of wack a bit. I always like to use what is called for. Best to go to your local Ace Hardware store and get a #47. They are in the hardware section around the flashlight bulbs. Best 2 U, George T
2/13/2014 4:20:14 PMNick
::Working on Montgomery ward AC. DC. tube radio late 40's
::calls for a #47 pilot light, all I have on hand is a
::#44. Will that work?
:: Thanks, nICK
:Hi Nick, it will work but it won't be as bright as the #47. It will however throw the voltages out of wack a bit. I always like to use what is called for. Best to go to your local Ace Hardware store and get a #47. They are in the hardware section around the flashlight bulbs. Best 2 U, George T
2/13/2014 4:20:57 PMNick
:: Thanks, nICK
Thanks, gearge
2/13/2014 6:04:42 PMLewis
:::Working on Montgomery ward AC. DC. tube radio late 40's
:::calls for a #47 pilot light, all I have on hand is a
:::#44. Will that work?
::: Thanks, nICK
::Hi Nick, it will work but it won't be as bright as the #47. It will however throw the voltages out of wack a bit. I always like to use what is called for. Best to go to your local Ace Hardware store and get a #47. They are in the hardware section around the flashlight bulbs. Best 2 U, George T
:Thanks, gearge
Nick:
two for $2.49 at Radio Shack.
2/19/2014 4:45:58 PMNick
: Thanks, nICK
on this same ac dc 5 tube radio I know where to connect
the positive lead of the signal generator, does negative go chassis ground, or B- ? Nick
2/19/2014 5:32:53 PMCV
Doesn't much matter since the sig gen is AC. On the off chance that your sig gen return is the same as that of the radio, you should connect the "low" side of the sig gen to chassis ground.
2/20/2014 9:30:53 AMnick
:Doesn't much matter since the sig gen is AC. On the off chance that your sig gen return is the same as that of the radio, you should connect the "low" side of the sig gen to chassis ground.
Thanks CV
