Since this is a SW band coil, it won't be that tough to rewind, having a much lower turns count than the associated BC band coil.
The three "tricks" in rewinding a coil are: (1) use the correct diameter wire; (2) wind the coils in the same direction (CW or CCW) as the original; and (3) keep the turns count same as the original.
If you manually rewind the coil, chances are the cosmetic result won't be pretty, but it will work fine.
Clifton
:Whoever rebuilds this coil will probably just strip both windings off the core and start from scratch. That way the number of turns for each winding can be positively determined.
:Since this is a SW band coil, it won't be that tough to rewind, having a much lower turns count than the associated BC band coil.
:The three "tricks" in rewinding a coil are: (1) use the correct diameter wire; (2) wind the coils in the same direction (CW or CCW) as the original; and (3) keep the turns count same as the original.
:If you manually rewind the coil, chances are the cosmetic result won't be pretty, but it will work fine.
:Or perhaps a down and dirty fix may be to wind a number of turns into a coil and stuff inside the SW oscillator coil and connect to the terminals of the original winding. May have to reverse the connections and experiment with the number of turns.
:Clifton
::Whoever rebuilds this coil will probably just strip both windings off the core and start from scratch. That way the number of turns for each winding can be positively determined.
::Since this is a SW band coil, it won't be that tough to rewind, having a much lower turns count than the associated BC band coil.
::The three "tricks" in rewinding a coil are: (1) use the correct diameter wire; (2) wind the coils in the same direction (CW or CCW) as the original; and (3) keep the turns count same as the original.
::If you manually rewind the coil, chances are the cosmetic result won't be pretty, but it will work fine.
Clifton
: Thanks for the re-winding thoughts , if I try to find a replacement , where might I start looking for a cross-reference list , translating which Meissner, Miller , ect.,coil might sub for my "open" Sparton SW osc. coil ?
: Another thought , could I use "any" generic / after-market, 4 lug, SW Osc. coil, to sub in directly ( without change ) for my open coil , even if the original DOESN'T have any adjustment trimmer ?
: Thanks again for your help, Lee Petrie , Joliet, IL.
::Or perhaps a down and dirty fix may be to wind a number of turns into a coil and stuff inside the SW oscillator coil and connect to the terminals of the original winding. May have to reverse the connections and experiment with the number of turns.
::Clifton
:::Whoever rebuilds this coil will probably just strip both windings off the core and start from scratch. That way the number of turns for each winding can be positively determined.
:::Since this is a SW band coil, it won't be that tough to rewind, having a much lower turns count than the associated BC band coil.
:::The three "tricks" in rewinding a coil are: (1) use the correct diameter wire; (2) wind the coils in the same direction (CW or CCW) as the original; and (3) keep the turns count same as the original.
:::If you manually rewind the coil, chances are the cosmetic result won't be pretty, but it will work fine.
:Generally the secondary or the unturned winding was not too critical. Just for kicks might wind some turns of wire about the same size as the original winding around the coil and attach to the connections of the open winding and see what happens. May have to reverse the connections.
:Clifton
:: Thanks for the re-winding thoughts , if I try to find a replacement , where might I start looking for a cross-reference list , translating which Meissner, Miller , ect.,coil might sub for my "open" Sparton SW osc. coil ?
:: Another thought , could I use "any" generic / after-market, 4 lug, SW Osc. coil, to sub in directly ( without change ) for my open coil , even if the original DOESN'T have any adjustment trimmer ?
:: Thanks again for your help, Lee Petrie , Joliet, IL.
:::Or perhaps a down and dirty fix may be to wind a number of turns into a coil and stuff inside the SW oscillator coil and connect to the terminals of the original winding. May have to reverse the connections and experiment with the number of turns.
:::Clifton
::::Whoever rebuilds this coil will probably just strip both windings off the core and start from scratch. That way the number of turns for each winding can be positively determined.
::::Since this is a SW band coil, it won't be that tough to rewind, having a much lower turns count than the associated BC band coil.
::::The three "tricks" in rewinding a coil are: (1) use the correct diameter wire; (2) wind the coils in the same direction (CW or CCW) as the original; and (3) keep the turns count same as the original.
::::If you manually rewind the coil, chances are the cosmetic result won't be pretty, but it will work fine.
Carefully rewinding the coil "from scratch" offers the best chance for getting the indicator needle to track the dial calibration. Trying to kludge in a repair or guess at a substitute coil may allow the set to pick up some stations, but the likelihood that the radio could be accurately aligned on the SW band seems low. But, maybe that is of no consequence to the present owner.
At any rate, trying something and failing won't damage the set any more than it already is (assuming that the repair strategy you choose doesn't involve charcoal and lighter fluid). Probably the best approach is to pick a repair plan that will not give a future owner of this set a reason to curse you out by introducing a "user mod" that the schematic doesn't cover.
you proceed with the repair depends on the results that you hope to achieve.
:Carefully rewinding the coil "from scratch" offers the best chance for getting the indicator needle to track the dial calibration. Trying to kludge in a repair or guess at a substitute coil may allow the set to pick up some stations, but the likelihood that the radio could be accurately aligned on the SW band seems low. But, maybe that is of no consequence to the present owner.
:At any rate, trying something and failing won't damage the set any more than it already is (assuming that the repair strategy you choose doesn't involve charcoal and lighter fluid). Probably the best approach is to pick a repair plan that will not give a future owner of this set a reason to curse you out by introducing a "user mod" that the schematic doesn't cover.
