I recently got my hands on an AMC stereo console with phono. Naturally, it didn't work when I got it home. A quick inspection of the amp revealed a burnt up power filter resistor. Replacing the resistor got power flowing across the unit, but the volume was very low. Here's what I've done so far...
1. Replaced all of the tubes with brand new ones.
Rectifier tube (6ca4) (replaced with JJ EZ81)
Preamp tube (6eu7) (replaced with Sovtek unit)
Power tubes (6bq5) 2x (replaced with JJ EL84s)
2. Replaced the power filter capacitors
3. Replaced the preamp cathode bypass resistors and capacitors (I noticed the resistance on the bypass resistor was supposed to be 22k ohm, but in the circuit it only checked out at 2.1k ohm - is this normal?)
4. Replaced the power tube cathode bypass capacitor.
5. Replaced the high voltage power resistors to the preamp tube (both were showing much higher than the rated 220k ohm - one at 330k and one at 600k).
6. I have bypassed the tuner/equalizer completely by using an off the shelf phono preamp to rule out the pots for volume/balance/bass/treble.
So all of this and I still have the same problem. Low volume at the speakers. What kind of voltage drop should I see across the speaker transformers? I'm dying to get this thing working, but I am really stuck here. Any help would be greatly appreciated!!!
I'm getting 360VDC off the rectifier tube, but a max of 24V at the power tubes and preamp tube. I would expect a much higher voltage draw if it were amplifying properly, right?
Does it matter which tube I start with?
I should probably disconnect the B+ line that goes to the tuner in case something in the tuner is drawing the power. I haven't even opened the tuner yet.
Thanks for the suggestions!!!
This is probably why your "filter resistor" burned out in the first place. Like fuses, they never fail for no reason at all.
It is in Sams Photofact 689-7. I checked my stacks and it is not one I have.
Richard
Greg; if you prefer you can email me a copy of the schematic and I will post it for you. If you click on on my name (Next to the "Posted by") it should pop up your email with my address in it.
Richard
Here's what I did...
1. Removed the Right channel 100nF cap to ground. No change.
2. Removed the Left channel 100nF cap to ground. No change.
3. Disconnected the high voltage to the tuner tubes from the power filter caps. No change.
4. Pulled the Left channel power tube. Voltage went up to 26V, but otherwise no change.
5. Ditto the Right channel power tube.
6. Swapped the preamp tube with an old one. No change.
7. Clipped the Left channel cathode bypass cap. No voltage change, but sound was getting worse.
8. Clipped the Right channel cathode bypass cap. Same as left.
9. Clipped the Left channel cathode bypass resistor and noticed the resistance across the mounting bracket was still 2.1k ohm without the resistor in place! There shouldn't be any connection across the bracket without the resistor unless it can go all the way through the preamp tube AND power tube. Is it possible that I'm getting something drawn back through the output transformers?
This set may have multiple problems, but the very low B+ voltage is one that will prevent it from performing and is also a fault that is pretty easy to troubleshoot if you are methodical and can resist the urge to "shotgun" stuff on a hunch. The "divine inspiration/hunch" method is more fun, but the "methodical approach" is more effective.
I don't think that an output tube fault could suck down that much voltage without the tube plate glowing bright red and (shortly after) self-destructing. Problem almost has to be in the output transformer side of things.
Usually when there is a plate-side bypass cap short, the transformer gets smoked (burned open) because it can't handle the DC current overload. But maybe your set has more robust transformers than others.
I'll try lifting the resistor (R73) then look at the transformers one by one.
If it does not go up then the issue is on the 300v source.
If it goes up to 300V (or thereabouts) then your draw is on the 280 or 250/220v source. Resolder it, lift the leg between R73 and R72.
If your 300V source goes up to around 300v then your issue is on the 250/220v source.
Richard
of the cause your initial problem of R74 charring /opening up. if you look more closely at the circuitry, you will see that the cathode resistor of the 6EU7 is also shunting ACROSS the pair.The same circuitry procedure is duped on the OTHER channel. and actually have a decade or centary higher value installed in place of a 150 ohm value . . .e.g. 1500 or 15000 ohms. |
:I would suggest lifting the leg of R73 between R73 and R72 and see if the 300V source goes up.
:If it does not go up then the issue is on the 300v source.
:If it goes up to 300V (or thereabouts) then your draw is on the 280 or 250/220v source. Resolder it, lift the leg between R73 and R72.
:If your 300V source goes up to around 300v then your issue is on the 250/220v source.
:Richard
Sir Edd,
I hope you're right about the red herring! I just really didn't want the problem to be coming from the transformers. I've already replaced C68A (and B, C, & D) and thought for sure that would fix my problem. I admit that my color code reading skills are weak, but my ability to read a number on a package should inspire confidence. :) (plus I checked it with my multimeter before I installed it.)
Did you install the electrolytic caps correctly? If installed "backwards" (+ to ground and - to B+), they will quickly overheat and short out internally when reverse-biased. Usually accompanied by interesting sound effects and projectile-vomited electrolyte.
Looking at the schematic, there are no plate bypass caps to worry about, so if the fault is on the 300V node, one of the audio output transformers is shorted. Not much else to point the finger at.
The 100nf caps that you snipped out had no possibility of drawing down the B+ bus since they are fed from B+ via a 220K ohm resistor.
Whatever the fault is, it is something that is sinking a heck of a lot of current. I'll bet that the resistor that you replaced is smokin' hot.
I replaced all of the caps and put the system back to normal.
I lifted R73 as Richard suggested and got C68B to 250V.
I replaced R73 and lifted R72
C68B = 250V
C68C = 86V
I cut the wire to the preamp tube and got
C68B = 250V
C68C = 140V
I replaced the wire to the preamp tube and cut the feed to the tuner
C68B = 250V
C68C = 96V
This suggests there is a problem in the 280V leg, but I replaced R72 just to see what things were like in the 250/220V leg.
C68A = 367V
C68B = 77V
C68C = 12.6V
C68D = 12.5V
I cut the 280V feed to the preamp tube and got
C68A = 367V
C68B = 70V
C68C = 12.9V
C68D = 12.7V
This suggested that I have an even bigger problem in the 250/220V leg going to the power tubes. So I started cutting wires to the individual tubes. I cut the Left tube first and got
A = 367V
B = 90V
C = 17.8V
D = 17.6V
Replaced the Left and cut the Right tube
A = 367V
B = 86V
C = 16.6V
D = 16.6V
Cut both tubes
A = 370V
B = 280V
C = 85V
D = 85V
Wait a minute...I may have switched the wiring to the C and D capacitors. So, if I'm feeding the preamp from C when it should be D, could that be the problem?
UNLESS the 6CA4 tube is worn out and can't supply enough B+ current to meet demand. In which case it will be loaded down to a very low voltage on its output (cathode pin).
The easiest way to check this is to take voltage readings across the first resistor in the string (R73)
with all of the loads connected and the set operating.
You can then calculate the current by dividing the measured differential voltage by the resistor value (measure the resistor, too, with the set off- resistors can ve mismarked). The tube is capable of outputting 100mA current; if the calculated value is much less than this, I would suspect that you have a weak rectifier tube.
No, and it's physically impossible for the first resistor to dissipate that much power: P=VI, so 340*2.2=748 watts. Absurd. As suggested earlier by someone in the thread, you probably have a resistor that is actually an order of magnitude or two larger that what you want (1,500 or 15,000 ohms, maybe even 150K). That would also account for the voltage drop under load, and the fact that the resistor apparently hasn't vaporized itself yet.
Not sure what you mean. You should be able to ohm from lead to lead on the resistor (i.e., at points on the leads just outside the body of the part) and get a reliable reading. (Make the readings with the set power off, of course.) If you suspect the solder joint at the lead ends, you can ohm from the lead to the solder surface where it attaches; if you get something other than zero ohms you have a bad joint.
I decided to remove all of the loads from the power filter capacitors except for the output transformers on C68B. When I do this voltages on all lines go up to where they are supposed to be.
A = 365V,
B = 280V,
C = 255V,
and D = 255V.
When I connect the preamp tube to D the voltage drops to 95V and everything else stays the same for A, B, and C although I do get a nasty hum through the speakers (both sides).
When I disconnect the preamp and connect either power tube the voltages drop all over.
B = 77V
C, and D = 17V
I intend to replace all of my power reistors when the new 470 Ohm 5 watt shows up, but I'm not sure where to go from there. Here's what I'm thinking...
Connect only the preamp to D. Lift C78 then C75 to see if the voltage goes up at D. If the voltage does go up then I have to figure out the issue at the power tubes. Does this seem logical?
Thanks for all of your help!
Thanks for your input!
