Kevin
You can use a choke rated at 10 henries @ 65 ma. The exact value is not critical. Also replace the filter caps in the radio with 10 mfd 450 volt.
The choke acts as a high resistance to AC and low for DC. It's AC resistance is determined by the formula 2piFL. (6.28X120X10) = 7536 ohms to ripple from the full wave rectifier while the DC resistance would be closer to 200 ohms..
