Gramophone cigarbox LF amplifier
2/5/2014 11:40:23 AMVan De Voode Marc
Marc Van De Voorde
:Belgium
:Hi, thanks for the support. Try if it succeeds.
If you see the picture, is the question.
:I find the brand and model of this unit.
Is an old Gramophone cigarbox LF amplifier
A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
A schedule is welcome
foto1
foto3
Best regards
Marc
2/5/2014 4:54:03 PMCV
Interesting unit. Doesn't appear to be a broadcast receiver, although the two tubes obscure most details behind them. Could be a phonograph amplifier, intercom/public address station, or early Soviet-style "propaganda cable set"... doesn't appear to be American in origin. It is somewhat reminiscent of the German volksempfänger sets, but only superficially.
2/6/2014 2:22:32 AMVan De Voorde Marc
:Interesting unit. Doesn't appear to be a broadcast receiver, although the two tubes obscure most details behind them. Could be a phonograph amplifier, intercom/public address station, or early Soviet-style "propaganda cable set"... doesn't appear to be American in origin. It is somewhat reminiscent of the German volksempfänger sets, but only superficially.
:Day CV,
to see to the construction of the chassis it is typical American. Just updated on 110 V and this is not common in Europe.
:Will probably have been just as an intercom.
3 connectors + an inverter "speaking/listening" thanks for the explanation, Marc
2/6/2014 8:12:21 AMCV
120 V operation doesn't identify it as "American". Most of Europe used 120V as its standard voltage prior to the start of the 1950s, although many countries used 50 Hz instead of 60 Hz as the frequency standard. The world (except for North America) changed over to 230V/50 Hz immediately after the conclusion of the second world war. Your item appears to be from the 1930s (closer to the start of the decade than the end) so it was probably made to operate on the then-standard of 120V. After the conversion, it was by then either obsolete and relegated to a storeroom, or operated for a while on a downconverter transformer.
Great Britain's power standard was actually 120V/60 Hz until after WW2, when the national power grid conversion was made to 230V/50 Hz.
The USA and other North American nations didn't convert for reasons similar to those given for never converting to the metric system: too many appliances/tools out there that were in use. Apparently the Great Depression-and-two-war-devastated Euro countries had much less of a "problem" with their citizens accumulating expensive electrical gadgetry than did the relatively unscathed USA.
The thing that made me think that it was a Euro set was the tube that is marked "MARCONI" on the bulb, even though it is marked RCA RADIOTRON on the base. Not very meaningful, I suppose, since the set probably went through at least a couple of tubes in its useful lifetime.
2/8/2014 5:12:56 AMVan De Voorde Marc
Dag CV,
:For WW2 was in Belgium the mains voltage 110 Volt.
After WW2 there was gradually changed to 220V.
:The whole unit is fitted with new components in the course of time, I also suspect the tubes.
:The type of tubes is original, type is listed in tube foot.
Best regards,
Marc
:120 V operation doesn't identify it as "American". Most of Europe used 120V as its standard voltage prior to the start of the 1950s, although many countries used 50 Hz instead of 60 Hz as the frequency standard. The world (except for North America) changed over to 230V/50 Hz immediately after the conclusion of the second world war. Your item appears to be from the 1930s (closer to the start of the decade than the end) so it was probably made to operate on the then-standard of 120V. After the conversion, it was by then either obsolete and relegated to a storeroom, or operated for a while on a downconverter transformer.
:Great Britain's power standard was actually 120V/60 Hz until after WW2, when the national power grid conversion was made to 230V/50 Hz.
:The USA and other North American nations didn't convert for reasons similar to those given for never converting to the metric system: too many appliances/tools out there that were in use. Apparently the Great Depression-and-two-war-devastated Euro countries had much less of a "problem" with their citizens accumulating expensive electrical gadgetry than did the relatively unscathed USA.
:The thing that made me think that it was a Euro set was the tube that is marked "MARCONI" on the bulb, even though it is marked RCA RADIOTRON on the base. Not very meaningful, I suppose, since the set probably went through at least a couple of tubes in its useful lifetime.
2/5/2014 8:02:15 PMBill G.
:Marc Van De Voorde
::Belgium
::Hi, thanks for the support. Try if it succeeds.
: If you see the picture, is the question.
::I find the brand and model of this unit.
: Is an old Gramophone cigarbox LF amplifier
:A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
: A schedule is welcome
:foto1
:foto3
:Best regards
:Marc
Hi Marc,
My vote is for intercom. One knob for talk/listen and the other for volume.
2/6/2014 2:32:28 AMVan De Voorde Marc
::Marc Van De Voorde
:::Belgium
:::Hi, thanks for the support. Try if it succeeds.
:: If you see the picture, is the question.
:::I find the brand and model of this unit.
:: Is an old Gramophone cigarbox LF amplifier
::A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
:: A schedule is welcome
::foto1
::foto3
::Best regards
::Marc
:Hi Marc,
: My vote is for intercom. One knob for talk/listen and the other for volume.
:Best Bill G,
Thanks for the input, as you say "an intercom" I have everything saved and a FM radio.
Will have a few images by sending.
Sorry for the bad English
Greetings, Marc
2/6/2014 5:54:44 AMLewis
:::Marc Van De Voorde
::::Belgium
::::Hi, thanks for the support. Try if it succeeds.
::: If you see the picture, is the question.
::::I find the brand and model of this unit.
::: Is an old Gramophone cigarbox LF amplifier
:::A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
::: A schedule is welcome
:::foto1
:::foto3
:::Best regards
:::Marc
::Hi Marc,
:: My vote is for intercom. One knob for talk/listen and the other for volume.
::Best Bill G,
: Thanks for the input, as you say "an intercom" I have everything saved and a FM radio.
: Will have a few images by sending.
: Sorry for the bad English
: Greetings, Marc
I wish I spoke another language as well as you speak English.
2/7/2014 5:23:00 PMEdd
Sir Marc . . . . . .
I also tend to want to go with Sir Bill Geeeee's mentioned, intercom aspect identification of the unit also.
The units skimpy tube lineup with their overall available low gain, tends to suggest this as being a REMOTE UNIT rather than THE MAIN unit.
Using its speaker as a microphone tends to require a bit of amplification gain, even when utilizing the reversed output transformer boost.
Wonder if those two large black, vertically stacked components just behind the speaker are being two power resistors (for filament dropping) ?
Also confirm that the left shaft coming out, now WITHOUT its attached knob, is having a SPRING LOADED RETURN ACTION.
If so, there was initially being a bar knob on that function switches shaft end. Normally the knob rests horizontally and is in its normal intercom
receive /listen mode,
you push down on the bar to TALK, then it pops back into its NORMAL intercom receive/listen mode, when being released.
Your photo sent is having a frontal profile somewhat akin to one of our antiquated Amerikanski sourced Executone units being shown below:
I now see the the bar/lever knob is not so clear, so here is another units view that uses that type of knob, which is showing up 'mo better.
en . . . . . .
gratie
. . . . .mijn Nederlands ..
Ik heb ook de neiging om te willen gaan met Sir Bill geeeee 's vermeld , intercom aspect identificatie van het apparaat ook .
De eenheden schraal buis lineup met hun totale beschikbare lage winst , heeft de neiging om dit te suggereren als een AFSTANDTOESTEL plaats van het hoofdtoestel.
Met behulp van de luidspreker als microfoon heeft de neiging om een beetje versterkingfactor vereisen , zelfs bij gebruik van de omgekeerde uitgangstransformator boost.
Vraag me af of die twee zwarte , verticaal gestapelde onderdelen net achter de luidspreker worden twee elektrische weerstanden ?
Ook bevestigen dat de linker as die uit zonder zijn bevestigd knop , is het hebben van een verende werking .
Zo ja, was er in eerste instantie dat het een bar knop op die functie schakelt aseinde . Normaal gesproken is de knop in horizontale stand steunt en is in zijn normale intercom ontvangen / luistermodus ,
je naar beneden duwt op de bar totalk , dan springt terug in zijn normale intercom ontvangen / luister modus , wanneer zij worden vrijgelaten .
Uw foto verzonden is met een frontale profiel iets wat lijkt op een van onze verouderde Amerikanski bronnenstudie Executone eenheden hieronder weergegeven :
Ik zie nu de de bar / hendel knop is niet zo duidelijk , dus hier is een andere eenheden mening dat deze soort knop , die is komen opdagen ' mo beter gebruikt .
::::Marc Van De Voorde
:::::Belgium
:::::Hi, thanks for the support. Try if it succeeds.
:::: If you see the picture, is the question.
:::::I find the brand and model of this unit.
:::: Is an old Gramophone cigarbox LF amplifier
::::A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
:::: A schedule is welcome
::::foto1
::::foto3
::::Best regards
::::Marc
:::Hi Marc,
::: My vote is for intercom. One knob for talk/listen and the other for volume.
:::Best Bill G,
:: Thanks for the input, as you say "an intercom" I have everything saved and a FM radio.
:: Will have a few images by sending.
:: Sorry for the bad English
:: Greetings, Marc
:I wish I spoke another language as well as you speak English.
:Lewis
2/7/2014 6:13:15 PMTerry F
Edd,
Glad to see you back on the forum. I always appreciated your help (and patience) with numerous problems I posted.
Terry F - St. Louis. MO.
2/8/2014 4:51:24 AMVan De Voorde Marc
Hoi Ed,
:It is now clear that this is an intercom telephone.
:I have removed of each part and thus a schedule.
:Indeed, the inverter jumps back to the booth listen.
:Wiring the inverter was not complete and I thought this was faulty.
:There have been many parts replaced.
I will send you a schedule what originally looked like.
:Probably tomorrow, I have my son needed.
He has to explain to me how this works.
:Best regards,
Marc.
Live the translation machine!
:Sir Marc . . . . . .
:I also tend to want to go with Sir Bill Geeeee's mentioned, intercom aspect identification of the unit also.
:The units skimpy tube lineup with their overall available low gain, tends to suggest this as being a REMOTE UNIT rather than THE MAIN unit.
:Using its speaker as a microphone tends to require a bit of amplification gain, even when utilizing the reversed output transformer boost.
:Wonder if those two large black, vertically stacked components just behind the speaker are being two power resistors (for filament dropping) ?
:Also confirm that the left shaft coming out, now WITHOUT its attached knob, is having a SPRING LOADED RETURN ACTION.
:If so, there was initially being a bar knob on that function switches shaft end. Normally the knob rests horizontally and is in its normal intercom
: receive /listen mode,
:you push down on the bar to TALK, then it pops back into its NORMAL intercom receive/listen mode, when being released.
:Your photo sent is having a frontal profile somewhat akin to one of our antiquated Amerikanski sourced Executone units being shown below:
:I now see the the bar/lever knob is not so clear, so here is another units view that uses that type of knob, which is showing up 'mo better.
:en . . . . . .
:gratie
: . . . . .mijn Nederlands ..
:Ik heb ook de neiging om te willen gaan met Sir Bill geeeee 's vermeld , intercom aspect identificatie van het apparaat ook .
:De eenheden schraal buis lineup met hun totale beschikbare lage winst , heeft de neiging om dit te suggereren als een AFSTANDTOESTEL plaats van het hoofdtoestel.
:Met behulp van de luidspreker als microfoon heeft de neiging om een beetje versterkingfactor vereisen , zelfs bij gebruik van de omgekeerde uitgangstransformator boost.
:Vraag me af of die twee zwarte , verticaal gestapelde onderdelen net achter de luidspreker worden twee elektrische weerstanden ?
:Ook bevestigen dat de linker as die uit zonder zijn bevestigd knop , is het hebben van een verende werking .
:Zo ja, was er in eerste instantie dat het een bar knop op die functie schakelt aseinde . Normaal gesproken is de knop in horizontale stand steunt en is in zijn normale intercom ontvangen / luistermodus ,
:je naar beneden duwt op de bar totalk , dan springt terug in zijn normale intercom ontvangen / luister modus , wanneer zij worden vrijgelaten .
:Uw foto verzonden is met een frontale profiel iets wat lijkt op een van onze verouderde Amerikanski bronnenstudie Executone eenheden hieronder weergegeven :
:Ik zie nu de de bar / hendel knop is niet zo duidelijk , dus hier is een andere eenheden mening dat deze soort knop , die is komen opdagen ' mo beter gebruikt .
:::::Marc Van De Voorde
::::::Belgium
::::::Hi, thanks for the support. Try if it succeeds.
::::: If you see the picture, is the question.
::::::I find the brand and model of this unit.
::::: Is an old Gramophone cigarbox LF amplifier
:::::A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
::::: A schedule is welcome
:::::foto1
:::::foto3
:::::Best regards
:::::Marc
::::Hi Marc,
:::: My vote is for intercom. One knob for talk/listen and the other for volume.
::::Best Bill G,
::: Thanks for the input, as you say "an intercom" I have everything saved and a FM radio.
::: Will have a few images by sending.
::: Sorry for the bad English
::: Greetings, Marc
::I wish I spoke another language as well as you speak English.
::Lewis
2/8/2014 10:07:48 AMLewis
:Hoi Ed,
::It is now clear that this is an intercom telephone.
::I have removed of each part and thus a schedule.
::Indeed, the inverter jumps back to the booth listen.
::Wiring the inverter was not complete and I thought this was faulty.
::There have been many parts replaced.
: I will send you a schedule what originally looked like.
::Probably tomorrow, I have my son needed.
: He has to explain to me how this works.
::Best regards,
: Marc.
: Live the translation machine!
::Sir Marc . . . . . .
::I also tend to want to go with Sir Bill Geeeee's mentioned, intercom aspect identification of the unit also.
::The units skimpy tube lineup with their overall available low gain, tends to suggest this as being a REMOTE UNIT rather than THE MAIN unit.
::Using its speaker as a microphone tends to require a bit of amplification gain, even when utilizing the reversed output transformer boost.
::Wonder if those two large black, vertically stacked components just behind the speaker are being two power resistors (for filament dropping) ?
::Also confirm that the left shaft coming out, now WITHOUT its attached knob, is having a SPRING LOADED RETURN ACTION.
::If so, there was initially being a bar knob on that function switches shaft end. Normally the knob rests horizontally and is in its normal intercom
:: receive /listen mode,
::you push down on the bar to TALK, then it pops back into its NORMAL intercom receive/listen mode, when being released.
::Your photo sent is having a frontal profile somewhat akin to one of our antiquated Amerikanski sourced Executone units being shown below:
::I now see the the bar/lever knob is not so clear, so here is another units view that uses that type of knob, which is showing up 'mo better.
::en . . . . . .
::gratie
:: . . . . .mijn Nederlands ..
::Ik heb ook de neiging om te willen gaan met Sir Bill geeeee 's vermeld , intercom aspect identificatie van het apparaat ook .
::De eenheden schraal buis lineup met hun totale beschikbare lage winst , heeft de neiging om dit te suggereren als een AFSTANDTOESTEL plaats van het hoofdtoestel.
::Met behulp van de luidspreker als microfoon heeft de neiging om een beetje versterkingfactor vereisen , zelfs bij gebruik van de omgekeerde uitgangstransformator boost.
::Vraag me af of die twee zwarte , verticaal gestapelde onderdelen net achter de luidspreker worden twee elektrische weerstanden ?
::Ook bevestigen dat de linker as die uit zonder zijn bevestigd knop , is het hebben van een verende werking .
::Zo ja, was er in eerste instantie dat het een bar knop op die functie schakelt aseinde . Normaal gesproken is de knop in horizontale stand steunt en is in zijn normale intercom ontvangen / luistermodus ,
::je naar beneden duwt op de bar totalk , dan springt terug in zijn normale intercom ontvangen / luister modus , wanneer zij worden vrijgelaten .
::Uw foto verzonden is met een frontale profiel iets wat lijkt op een van onze verouderde Amerikanski bronnenstudie Executone eenheden hieronder weergegeven :
::Ik zie nu de de bar / hendel knop is niet zo duidelijk , dus hier is een andere eenheden mening dat deze soort knop , die is komen opdagen ' mo beter gebruikt .
::73's de Edd
::::::Marc Van De Voorde
:::::::Belgium
:::::::Hi, thanks for the support. Try if it succeeds.
:::::: If you see the picture, is the question.
:::::::I find the brand and model of this unit.
:::::: Is an old Gramophone cigarbox LF amplifier
::::::A:Originally there were 3 tubes in: 6C6-25A7 and probably a ballast tube can someone give more information?
:::::: A schedule is welcome
::::::foto1
::::::foto3
::::::Best regards
::::::Marc
:::::Hi Marc,
::::: My vote is for intercom. One knob for talk/listen and the other for volume.
:::::Best Bill G,
:::: Thanks for the input, as you say "an intercom" I have everything saved and a FM radio.
:::: Will have a few images by sending.
:::: Sorry for the bad English
:::: Greetings, Marc
:::I wish I spoke another language as well as you speak English.
:::Lewis
Sir Edd:
I must disagree with you about that box being a slave unit rather than a master. Back in my teens, I converted an AA5 into an intercom by using an output transformer wired backward to match the slave voice coil to the radio first audio grid. I could sit in my workshop and hear everything my parents said. Learned a lot from that intercom. Mom and dad thought they had to press a button for me to hear, but I could override the button and hear the kitchen and living room very clearly with just two amplifier tubes.
2/12/2014 2:20:30 AMVan De Voorde Marc
:Good morning, as promised in the annex originally schedule
:I'm not sure if it's true at all.
The unit has already undergone an overhaul long ago.
:To distract the old worn out inverter.
:In the end everything converted to a hybrid FM radio!
Best regards, Marc
:Hoi Ed,
::Best regards,
: Marc.
::en . . . . . .
::gratie
::73's de Edd
:::::::Belgium
::::::foto1
::::::foto3
::::::Best regards
::::::Marc
:::::Hi Marc,
:::::Best Bill G,
:::Lewis
