7s633 zenith
2/2/2014 9:13:32 AMsmith(110426:0)
will a 6c5,6j5....will these work for a 6p5 tube in this zenith.
2/2/2014 9:19:45 AMsmith(110427:110426)
:will a 6c5,6j5....will these work for a 6p5 tube in this zenith.
:also i have a 6x5,6x5g,6x5gt..which one would be better.
2/2/2014 9:44:09 AMJohn(110431:110427)
::will a 6c5,6j5....will these work for a 6p5 tube in this zenith.
::also i have a 6x5,6x5g,6x5gt..which one would be better.
Not sure what to tell you about the 6X5's but some had a problem shorting and taking out the power transformer when this happened. If me, I would make sure and fuse them. Maybe someone else can tell you which ones to use that weren't susceptable to shorts.
2/2/2014 9:49:22 AMsmith(110432:110431)
:::will a 6c5,6j5....will these work for a 6p5 tube in this zenith.
:::also i have a 6x5,6x5g,6x5gt..which one would be better.
:Not sure what to tell you about the 6X5's but some had a problem shorting and taking out the power transformer when this happened. If me, I would make sure and fuse them. Maybe someone else can tell you which ones to use that weren't susceptable to shorts.
:where do i fuse at what pin and tube and what size fuse,thanks for your help
2/2/2014 9:29:22 AMJohn(110428:110426)
My old sub book copyright 1950 says both of these are subs for a 6P5 and rates their performance as GOOD.
2/2/2014 9:39:43 AMsmith(110430:110428)
:My old sub book copyright 1950 says both of these are subs for a 6P5 and rates their performance as GOOD.
:thanks john,any thing about the 6x5
2/2/2014 9:58:17 AMCV(110434:110430)
...any thing about the 6x5
They have the same electrical spec- only difference is packaging, metal (6X5) or glass bulb shape (G, GT). Use whatever suits your taste.
2/2/2014 10:05:59 AMsmith(110435:110434)
:...any thing about the 6x5
:They have the same electrical spec- only difference is packaging, metal (6X5) or glass bulb shape (G, GT). Use whatever suits your taste.
:they said i should fuse this tube what pin and what size fuse
2/2/2014 10:17:09 AMCV(110439:110435)
You can fuse the B+ bus, the AC line, or both. If you fuse the AC line, a 1 amp fuse should be adequate; half an amp on B+.
Not fusing B+ won't lead to a safety issue; but it might save your 6X5 tube from self-destructing if something on B+ (such as a filter cap) ever shorts to ground.
Fusing the AC line input is always a good idea. If something shorts out the AC line inside the radio, it can cause a fire before the (usually high-current) breaker in the house service panel trips.
2/2/2014 10:30:17 AMsmith(110440:110439)
:You can fuse the B+ bus, the AC line, or both. If you fuse the AC line, a 1 amp fuse should be adequate; half an amp on B+.
:Not fusing B+ won't lead to a safety issue; but it might save your 6X5 tube from self-destructing if something on B+ (such as a filter cap) ever shorts to ground.
:Fusing the AC line input is always a good idea. If something shorts out the AC line inside the radio, it can cause a fire before the (usually high-current) breaker in the house service panel trips.
:will fuse b+,try and save a transformer
2/2/2014 11:47:43 AMJohn(110441:110440)
::You can fuse the B+ bus, the AC line, or both. If you fuse the AC line, a 1 amp fuse should be adequate; half an amp on B+.
::Not fusing B+ won't lead to a safety issue; but it might save your 6X5 tube from self-destructing if something on B+ (such as a filter cap) ever shorts to ground.
::Fusing the AC line input is always a good idea. If something shorts out the AC line inside the radio, it can cause a fire before the (usually high-current) breaker in the house service panel trips.
::will fuse b+,try and save a transformer
:You can google 6X5 replacement options/advice and it will bring up a forum discussion from Antique Radio site and you can learn what others have done about replacing the 6X5.
