Detrola 2811 line resistor
2/1/2014 4:05:25 PMDale
Hi all, im working on this set, line resistor was found open on the short section, this has part # 6124 three connections and is a wire wound resistor in a metal sleeve that is riveted to the chassis for heat sink purposes I think, was able to find a good one out of a part chassis. My next problem is how close to the values can I go with replacement paper caps, i need a .15 mfd but i have a .1 and my next available is a .2? I forgot how tedious those small radios are to work on, just all components are packed in so tight, lots of coffee and patience, long tweezers help too!!!!
2/1/2014 5:46:19 PMCV
Either one will work OK; but as a general rule, when in doubt use a higher-value cap (not to exceed 100% of the nominal value).
2/1/2014 6:27:47 PMDale
:Either one will work OK; but as a general rule, when in doubt use a higher-value cap (not to exceed 100% of the nominal value).
Ah ok, my thought was going a bit higher, just didnt know how much was acceptable, in this case 25% is all good,
Thank You
2/3/2014 4:05:24 PMDale
::Either one will work OK; but as a general rule, when in doubt use a higher-value cap (not to exceed 100% of the nominal value).
:Ah ok, my thought was going a bit higher, just didnt know how much was acceptable, in this case 25% is all good,
:Thank You
All done recapping and installing replacement resistor, now found 2 tubes with open heater filaments so the search is on for some good tubes!
2/3/2014 5:45:29 PMDennis Wess
Dale:
You can come very close to the required value by connecting two capacitors in PARALLEL. The overall voltage rating will be whatever the lowest rating of the pair is.
i.e. > .1uf(@400v) + .047uf(@630v) (wired in parallel) = .147uf total capacitance (@400v) ..... pretty close to the .15uf requirement.
2/3/2014 6:07:34 PMDale
:Dale:
:You can come very close to the required value by connecting two capacitors in PARALLEL. The overall voltage rating will be whatever the lowest rating of the pair is.
:i.e. > .1uf(@400v) + .047uf(@630v) (wired in parallel) = .147uf total capacitance (@400v) ..... pretty close to the .15uf requirement.
Thank You Dennis, adding extra components in this chassis is pretty difficult, real estate is not there, although the new caps are typically a lot smaller, I found another big blunder, previous person installed a 35z5 tube instead if a 35z4, probably what burnt out that resistor and possibly those 2 other tubes,
2/3/2014 7:12:17 PMClifton
The 35Z5 will probably work ok. Would just make sure there was nothing connected to pin 3 of the tube socket.
Clifton
::Dale:
::You can come very close to the required value by connecting two capacitors in PARALLEL. The overall voltage rating will be whatever the lowest rating of the pair is.
::i.e. > .1uf(@400v) + .047uf(@630v) (wired in parallel) = .147uf total capacitance (@400v) ..... pretty close to the .15uf requirement.
:Thank You Dennis, adding extra components in this chassis is pretty difficult, real estate is not there, although the new caps are typically a lot smaller, I found another big blunder, previous person installed a 35z5 tube instead if a 35z4, probably what burnt out that resistor and possibly those 2 other tubes,
2/3/2014 7:44:08 PMDale
:The 35Z5 will probably work ok. Would just make sure there was nothing connected to pin 3 of the tube socket.
:Clifton
:yes thats exactly what happened, pin 3 was being used as a connection point and it shorted out a section of the heater string causing over voltage to the rest of the tubes
:::Dale:
:::You can come very close to the required value by connecting two capacitors in PARALLEL. The overall voltage rating will be whatever the lowest rating of the pair is.
:::i.e. > .1uf(@400v) + .047uf(@630v) (wired in parallel) = .147uf total capacitance (@400v) ..... pretty close to the .15uf requirement.
::Thank You Dennis, adding extra components in this chassis is pretty difficult, real estate is not there, although the new caps are typically a lot smaller, I found another big blunder, previous person installed a 35z5 tube instead if a 35z4, probably what burnt out that resistor and possibly those 2 other tubes,
