Dial Lamps for Rogers Majestic
2/19/2002 11:43:12 PMLeon
I have a Rogers Majestic R555 and am looking to source
a couple of dial lamps. This uses screw-in 6 watt 125V
lamps. The screw-in part is 1/2 inch in width and the
total length (including screw-in portion) is an inch and
3/4 long. I tried Tubes and More but they have nothing
listed. Can anyone point me in the right direction?
Thanks in advance.
2/20/2002 9:36:34 PMJeff
Hi Leon,
There is no guarantee but you might try Play Things of the Past at http://www.oldradioparts.com. Try contacting them via the e-mail link on the site. Very good service and good selection.
Jeff
: I have a Rogers Majestic R555 and am looking to source
: a couple of dial lamps. This uses screw-in 6 watt 125V
: lamps. The screw-in part is 1/2 inch in width and the
: total length (including screw-in portion) is an inch and
: 3/4 long. I tried Tubes and More but they have nothing
: listed. Can anyone point me in the right direction?
: Thanks in advance.
3/29/2010 12:43:02 PMLeon
Hi, thanks. I will try there. A good radio but for some reason this info was not on the schematics.
Leon
:Hi Leon,
:There is no guarantee but you might try Play Things of the Past at http://www.oldradioparts.com. Try contacting them via the e-mail link on the site. Very good service and good selection.
:Jeff
:: I have a Rogers Majestic R555 and am looking to source
:: a couple of dial lamps. This uses screw-in 6 watt 125V
:: lamps. The screw-in part is 1/2 inch in width and the
:: total length (including screw-in portion) is an inch and
:: 3/4 long. I tried Tubes and More but they have nothing
:: listed. Can anyone point me in the right direction?
:: Thanks in advance.
3/29/2010 5:53:06 PMNorm Leal
Hi
Another place to try is Bulb Direct. www.bulbdirect.com . They will have what you need but may have to look through lots of lamps.
:Hi, thanks. I will try there. A good radio but for some reason this info was not on the schematics.
:Leon
::Hi Leon,
::There is no guarantee but you might try Play Things of the Past at http://www.oldradioparts.com. Try contacting them via the e-mail link on the site. Very good service and good selection.
::Jeff
::: I have a Rogers Majestic R555 and am looking to source
::: a couple of dial lamps. This uses screw-in 6 watt 125V
::: lamps. The screw-in part is 1/2 inch in width and the
::: total length (including screw-in portion) is an inch and
::: 3/4 long. I tried Tubes and More but they have nothing
::: listed. Can anyone point me in the right direction?
::: Thanks in advance.
3/29/2010 7:40:59 PMJohn Pfouts
:Hi
: Another place to try is Bulb Direct. www.bulbdirect.com . They will have what you need but may have to look through lots of lamps.
::Hi, thanks. I will try there. A good radio but for some reason this info was not on the schematics.
::Leon
:::Hi Leon,
:::There is no guarantee but you might try Play Things of the Past at http://www.oldradioparts.com. Try contacting them via the e-mail link on the site. Very good service and good selection.
:::Jeff
:::: I have a Rogers Majestic R555 and am looking to source
:::: a couple of dial lamps. This uses screw-in 6 watt 125V
:::: lamps. The screw-in part is 1/2 inch in width and the
:::: total length (including screw-in portion) is an inch and
:::: 3/4 long. I tried Tubes and More but they have nothing
:::: listed. Can anyone point me in the right direction?
:::: Thanks in advance.
Hi Leon,
How about a 6F6 bulb ? Sounds about right for the description you gave.
John
