Don't be discouraged that the wire color coding is gone. Every wire's connections in the set can be determined by tracing its physical start and end points against the schematic, then determining for yourself how the wires are laid out in the actual chassis. Color coding was necessary for some parts of the initial assembly of the set but is not needed at all for repair. Just don't indulge in bulk disconnection of wires- replace one at a time.
