Troy:
I wouuldn't worry about it. The ballast tube should compensate for the difference, and the Voltage is less than five per cent higher than rated, anyhow.
The main enemy of tube longevity in transformerless sets like yours is inrush current: when a set is first turned on, the heaters are cold and so are relatively low resistance. This means that a fairly large current surge flows through the filament string prior to heater warmup when you flip the "on" switch. This surge, repeated often enough, will eventually open up the weakest heater in the string. It has been estimated that turn-on current surges reduce the life of tubes by about 50%.
This can be prevented by installing a surge-limiting device in the set such as a surgistor. The trick in using these is selecting one that is matched to the normal current draw of your set; otherwise it will not operate correctly and will drop excessive voltage across itself.
However, if the set is going to mainly be a "shelf queen" and not a daily player, I wouldn't worry about it. If the set will get used extensively and flipped on and off many times a day, it is something to consider.
It seems to me the dial lamp serves as a surge protector on some sets, no?
Maybe add a bulb to the heater string?
The CL-90, and its sister versions were initially G.E. products. Something tells me that the CL line was sold to another manufacturer? Not sure. If you Google CL-90, you will find them.
They are just thermistors, as are often used for temperature measurement. The higher the temperature, the lower the resistance.
Most tubes that fail burn out at turn on, just like incandescent lamps.
