There is a dropping resistor immediately after the diode. When I apply power this glows red hot and eventually cracks in half, shorted it would seem.
I'm trying to retrace my connections as shown in the schematic but I can't find what I'm overlooking. I am merely an aspiring tube radio technician & this is my first true test!
Anyone have any hints for me?
If it did, I would suspect that you inadvertently reverse-connected at least one of the electrolytic filter caps; or perhaps created a solder splash short-circuit from B+ to ground in the course of doing the repair work.
If the set didn't function prior to your work on it, and you are certain that the new caps are correctly installed, you might check each tube for the correct number and that it is installed in the proper socket.
Yes it did work, although it had some issues of course - the main one being AC hum.
Thanks for the tip. I'll focus my troubleshooting on the new capacitor bank.
Best regards,
Bill Grimm
