schematic oscil. tektronix type 547 and more...
4/6/1999 7:02:50 PMjulio
help to find:schematic oscil. tektronix type 547,
info for the tube og3 and for the transistor
RAY 151 096 433
tnx
jjulio
4/6/1999 10:32:48 PMNorm Leal
: help to find:schematic oscil. tektronix type 547,
: info for the tube og3 and for the transistor
: RAY 151 096 433
: tnx
: jjulio
Hi Julio
Tektronix can be reached by phone 503-627-7111 or fax 503-627-5502, 503-627-1112. They print an Instruction Manual with schematics for each section of the oscilloscope. I have the 545B book and it's about 100 pages.
The 0G3 tube is also known as 85A2. It is a regulator for 85 volts from 1-10 ma. It holds regulation to within 3 volts and takes 115 volts to start.
Did not find anything on the Raytheon Transistor. It was probably a special, made for another company.
4/8/1999 12:48:17 PMBob Carpenter
: : help to find:schematic oscil. tektronix type 547,
: : info for the tube og3 and for the transistor
: : RAY 151 096 433
: : tnx
: : jjulio
: Hi Julio
: Tektronix can be reached by phone 503-627-7111 or fax 503-627-5502, 503-627-1112. They print an Instruction Manual with schematics for each section of the oscilloscope. I have the 545B book and it's about 100 pages.
: The 0G3 tube is also known as 85A2. It is a regulator for 85 volts from 1-10 ma. It holds regulation to within 3 volts and takes 115 volts to start.
: Did not find anything on the Raytheon Transistor. It was probably a special, made for another company.
: Norm
Hi Julio
You didn't say much about the transistor use and location
so I'll try to help you as much as I can. There are only
three locations in the '547 that use a 151-096. Don't
worry about the -433. 151-096 is a Tektronix in-house
number and the -433 is a trace number. Any way, if this
transistor is used in the "A" or the "B" sweep generator
then it can be replaced by a selected 2N1893 or ECG154.
Any NPN Silicon transistor that has the following ratings
can be used.
Vcbo=300v
Vceo=300v
Vebo=7v
Ic=0.5A
Dissipation=1W
ft=40Mhz
hfe=60 typical
Good Luck
Bob
6/30/2000 8:02:21 AMlorenzo silvestri
: : : help to find:schematic oscil. tektronix type 547,
: : : info for the tube og3 and for the transistor
: : : RAY 151 096 433
: : : tnx
: : : jjulio
: : Hi Julio
: : Tektronix can be reached by phone 503-627-7111 or fax 503-627-5502, 503-627-1112. They print an Instruction Manual with schematics for each section of the oscilloscope. I have the 545B book and it's about 100 pages.
: : The 0G3 tube is also known as 85A2. It is a regulator for 85 volts from 1-10 ma. It holds regulation to within 3 volts and takes 115 volts to start.
: : Did not find anything on the Raytheon Transistor. It was probably a special, made for another company.
: : Norm
: Hi Julio
: You didn't say much about the transistor use and location
: so I'll try to help you as much as I can. There are only
: three locations in the '547 that use a 151-096. Don't
: worry about the -433. 151-096 is a Tektronix in-house
: number and the -433 is a trace number. Any way, if this
: transistor is used in the "A" or the "B" sweep generator
: then it can be replaced by a selected 2N1893 or ECG154.
: Any NPN Silicon transistor that has the following ratings
: can be used.
: Vcbo=300v
: Vceo=300v
: Vebo=7v
: Ic=0.5A
: Dissipation=1W
: ft=40Mhz
: hfe=60 typical
: Good Luck
: Bob
