Respectfully,
Charles
The Horizontal sweep circuit isn't operating. The circuit will use an oscillator and amplifier. This signal is fed into CRT deflection plates.
Your scope will have a switch to select different horrizontal frequencies. It may have one position which turns off this oscillator. Rotate the switch and see what happens.
: I pick up this scope on a trade this last weekend at the SARS meet outside of Atlanta and it worked with a pair of sine waves, very responsive for about 5 minutes then there were a pair of dots that responded vertically but not horizontally. I would like to salvage this scope and learn how to use it. How should I proceed to diagnose and repair this device? Any and all help would be appreciated
: Respectfully,
: Charles
Charles
: Hi Charles
: The Horizontal sweep circuit isn't operating. The circuit will use an oscillator and amplifier. This signal is fed into CRT deflection plates.
: Your scope will have a switch to select different horrizontal frequencies. It may have one position which turns off this oscillator. Rotate the switch and see what happens.
: Norm
: : I pick up this scope on a trade this last weekend at the SARS meet outside of Atlanta and it worked with a pair of sine waves, very responsive for about 5 minutes then there were a pair of dots that responded vertically but not horizontally. I would like to salvage this scope and learn how to use it. How should I proceed to diagnose and repair this device? Any and all help would be appreciated
: : Respectfully,
: : Charles
Yes, replace any cap the gets warm. That's a common failure mode of electrolytic caps. They get leaky, heat, short and can destroy other components in your scope. Replacing it may cause your scope to start operating again?
: I tried the knob you suggested and all of the others
: with no luck. I did notice a smell coming from the scope and discovered an electrolytic cap that is hot to the touch. Should my assumption be that this cap has failed and replace it?
: Charles
: : Hi Charles
: : The Horizontal sweep circuit isn't operating. The circuit will use an oscillator and amplifier. This signal is fed into CRT deflection plates.
: : Your scope will have a switch to select different horrizontal frequencies. It may have one position which turns off this oscillator. Rotate the switch and see what happens.
: : Norm
: : : I pick up this scope on a trade this last weekend at the SARS meet outside of Atlanta and it worked with a pair of sine waves, very responsive for about 5 minutes then there were a pair of dots that responded vertically but not horizontally. I would like to salvage this scope and learn how to use it. How should I proceed to diagnose and repair this device? Any and all help would be appreciated
: : : Respectfully,
: : : Charles
