AK185A
1/17/2014 9:17:37 PMNeal Buddenberg
What would make an AK 185A screech when you turn the Volume control? The radio has been recapped and plays well in all respects, and the noise stops a few seconds after you stop moving the knob...Thanks
1/17/2014 9:30:15 PMCV
My guess is that the pot wiper is either dirty or worn so that it "skips" as it is moved across the resistance element. When that happens, the input to the first audio amp goes open, letting it pick up AC from the same or subsequent audio stage and causing feedback- the "screech" that you hear.
I would first check the wire routing around the volume pot and detector/first audio amp tube- it possibly got changed when the set was recapped. If that doesn't solve the problem, a volume pot replacement might be necessary.
