::Here's some info to consider on the swap...
::A 5Y3 is limited to 125 ma current, 5U4G can supply 225 ma. There is also a difference in internal voltage drop within the tube. A 5U4G will have a lower voltage drop than 5Y3.
:: One other important item to consider - 5Y3 has a 2 amp filament while 5U4 3 amps. This is ok if a transformer can handle the extra filament current without overheating
::so it needs a 5y3 to help out on the transf.
Yes. I wouldn't make that substitution due mainly to the filament current. That can cause damage to the power transformer.
All the Best,
Bill Grimm
