Best regards,
Bill Grimm
If I understand the original post correctly (and I may have misinterpreted it) the poster was asking if it was possible to "snip out" the IF transformer entirely and go directly from the converter output to the detector via an RC coupling. Don't think so- although the Lone Ranger set is just a small step above that! Any simpler and you'd have a single-stage TRF set.
1: Converter/Oscillator tube
2: IF Amp
3: Detector/1st Audio
4: Audio Output
5: Rectifier
Tube types varied with the era of the set, going from octal-based tubes in the 30s to miniature tubes in the late 40s through to the end of tubedom.
Can't say that I've ever heard of an "All American Four".
http://radioattic.com/item.htm?radio=1090415
And all of the Arvin metal midgets.
http://www.nostalgiaair.org/PagesByModel/494/M0003494.pdf
For the record, this is a good Description of the AA5 set.
http://www.radiophile.com/adm3725r.htm
The AA4 (I, too, have not heard the term before) omitted the IF amplifier tube. This tube typically provides the lion's share of signal amplification.
The AA6 had an RF section ahead of the mixer. It would be the same type of tube used for the IF.
As mentioned before it was done to reduce cost and/or size. The Lone Ranger sets were sold to fit into a child's crowded bedroom. It was small in size.
All the Best,
Bill Grimm
