That is a difficult question. The load on the secondary is reflected back into the primary. For example, if you have a 1:1 turns ratio, and connect the secondary to a 10K load, the primary impedance will be 1K Ohms. You really need to know the turns ratio rather than the impedance of the transformer.
But practically speaking, this is a "don't care". ITs are nice when driving push-pull output tubes, since they eliminate the need for an inverter tube, but for AM broadcast reception they don't add much (if anything) fidelity-wise. Particularly when one considers the limitations of most of the loudspeakers of the day.
500K in the plate circuit seems high to me, but it's tough to argue with success.
I did lower the plate circuit to 250k on the 27 tube.
It does seem high but works very well.
Chuck
CV, I did some more playing around. I have the plate resistor down to 20k and the plate voltage is about where it belongs. I can get more volume.
Chuck
Thanks Lewis and CV. I did change the #27 plate resistor to 50K. Works fine and plate voltage somewhat lower than on schematic. That is OK as plenty of volume and clear sound. Glad to increase the life of the 27 tube
Chuck
