Rod antennas are easy to make. Try Google for more info.
Ferrite is a powdered iron (or other magnetic material) which is pressed into rods and other shapes.
http://www.amidoncorp.com/r61-025-400/
Rich
Small antenna size first became important in portable radios, especially transistor sets. However, ferrite antennas were sometimes used in later tabletop or console tube sets because of their additional unique properties of being highly directional and (if fitted with a grounded aluminum "tent" ) able to reject noise that is borne on the e-field component of the radio wave. German radio manufacturers of the 50s and 60s usually used internal ferrite-rod antennas on the standard broadcast and longwave AM bands. Some were rotatable by a knob on the front panel to allow the radio user to maximize reception by adjusting the rod's direction without needing to move the entire set.
Small size, however, is the principal reason for ferrite antennas becoming popular in the tiny AM BC radios that flourished starting in the late 50's. Ferrite rod antennas don't have much of an advantage over standard wire-loop or long-wire antennas in a typical large tube-style AM radio, and they are pretty much useless at the much higher frequencies of shortwave and FM.
Therefore, if you want to replace a wire loop (factory) antenna with a ferrite rod antenna, you will need to match the inductance of the original antenna in order to avoid loss of sensitivity. This inductance value can be computed from the loop wire diameter, the number of turns, and the loop dimensions. With this info in hand you can compute the necessary characteristics of an equivalent ferrite antenna (wire diameter, ferrite core diameter, # of coil turns) in order to match the factory unit's inductance.
There's an old adage in radio which is, "If you want better reception, put up more metal."
Ray:
I would say that as long as the inductance of the loop can resonate with the tuning capacitor, and all of them are 365 pF at the low end of the band, then whatever you put into the radio should be about the same. There is a trimmer cap on the main cap to peak the radio for max performance. You are not going to burn the house down by expermenting with loops, so I avise that you experiment.
Building MW ferrite antennas:
https://googledrive.com/host/0B4azXCQ9cxMZbmppcjBVc25aLVk/ARADARCHIVE/comp&data/mwcoildata0564pw/page1.jpg
Rich
